No rule to make target `/mnt/prog/lib/libpython3.3m.so'
vanangamudi
Post by vanangamudi »
Everything goes fine(just a guess!)
but when the compilation finished, it says no rule to make libpython3.3m.so, which is already built shared object(I compiled it separately from the blender). what is actually going on??
Scanning dependencies of target blender
[100%] Building C object source/creator/CMakeFiles/blender.dir/creator.c.o
[100%] Building C object source/creator/CMakeFiles/blender.dir/buildinfo.c.o
make[2]: *** No rule to make target `/mnt/prog/lib/libpython3.3m.so', needed by `bin/blender'. Stop.
make[1]: *** [source/creator/CMakeFiles/blender.dir/all] Error 2
make: *** [all] Error 2
here is the full screenshot of the output
http://paste.ubuntu.com/5579080/
~vanangamudi
I gotta admit. blender is awesome in both dimensions. before and after compilation.
Post by stiv »
Is that the actual location of the library?
Did you add that path to your build config?
vanangamudi
YAML::functions() not available
this I got solved with help of @plasmasolutions from #blendercoders. I mistyped $PROGB(correct) as $PROG(wrong).
but after reconfiguring and compiling, the dependencies of OpenColorIO, TinyXML (which I didn't installed at the time) was used as a problem to throw errors on my face.
and I installed TinyXML development package. and it got solved too. now another dependency YAML is being reported "not found" and I installed yaml development package but this problem is not solved. it again shows
/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/libOpenColorIO.a(OCIOYaml.cpp.o): In function `void YAML::operator>><float>(YAML::Node const&, std::vector<float, std::allocator<float> >&)':
(.text._ZN4YAMLrsIfEEvRKNS_4NodeERSt6vectorIT_SaIS5_EE[void YAML::operator>><float>(YAML::Node const&, std::vector<float, std::allocator<float> >&)]+0x3a7): undefined reference to `YAML::Iterator::~Iterator()'
(.text._ZN4YAMLrsIfEEvRKNS_4NodeERSt6vectorIT_SaIS5_EE[void YAML::operator>><float>(YAML::Node const&, std::vector<float, std::allocator<float> >&)]+0x410): undefined reference to `YAML::Iterator::~Iterator()'
collect2: ld returned 1 exit status
make[2]: *** [bin/blender] Error 1
or Can I disable OpenColorIO for now. If so, how??
~vanangamudi
ldo
Post by ldo »
I built OpenColorIO from source. It wasn’t hard, as I recall.
vanangamudi
how to pass the path of OCIO to blender
ldo wrote:I built OpenColorIO from source. It wasn’t hard, as I recall.
I do like to build softwares from source. I will try it with OCIO. but after building how to pass the path to blender, while building it. is there any variables like OPENCOLOR_IO_PATH simlar to PYTHON_LIBRARY ???
~vanangamudi
ldo
Post by ldo »
Yes, you can pass all that kind of thing in CMake variables. I have a wrapper script I use to build Blender, here is the line in it that does the CMake setup (notice all the explicit OPENCOLORIO_xxx and OPENIMAGEIO_xxx definitions):
cmake \
    -D WITH_PLAYER=ON \
    -D WITH_PYTHON_INSTALL=OFF -D PYTHON_VERSION=3.3 \
    -D PYTHON_INCLUDE_DIR=/usr/include/python3.3m \
    -D PYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.3m.so \
    -D WITH_FFTW3=ON -D WITH_MOD_OCEANSIM=ON \
    -D OPENCOLORIO_INCLUDE_DIR=/usr/local/OpenColorIO/include \
    -D OPENCOLORIO_OPENCOLORIO_LIBRARY=/usr/local/OpenColorIO/lib/libOpenColorIO.so \
    -D OPENCOLORIO_TINYXML_LIBRARY=/usr/local/OpenColorIO/lib/libtinyxml.a \
    -D OPENCOLORIO_YAML-CPP_LIBRARY=/usr/local/OpenColorIO/lib/libyaml-cpp.a \
    -D OPENIMAGEIO_INCLUDE_DIR=/usr/include \
    -D OPENIMAGEIO_LIBRARY=/usr/lib/libOpenImageIO.so \
    -D WITH_OPENCOLLADA=ON \
    -D WITH_CODEC_FFMPEG=ON -D FFMPEG=/usr/local -D WITH_JACK=ON \
    -D FFMPEG_LIBRARIES="avdevice;avfilter;avformat;avcodec;avutil;swscale;swresample;postproc;nut;bz2;faac;faad;gsm;jack;modplug;mp3lame;opencore-amrnb;opencore-amrwb;rtmp;schroedinger-1.0;speex;theoraenc;theoradec;vpx;x264;xvidcore" \
    -D WITH_CODEC_SNDFILE=ON \
    ../"$SRCDIR"
(../"$SRCDIR" is the Blender source directory,)
vanangamudi
I did so. and compiled blender succesfully
ldo wrote:Yes, you can pass all that kind of thing in CMake variables. I have a wrapper script I use to build Blender, here is the line in it that does the CMake setup (notice all the explicit OPENCOLORIO_xxx and OPENIMAGEIO_xxx definitions):
cmake \
    -D WITH_PLAYER=ON \
    ../"$SRCDIR"
I compiled blender successfully.
more elaborate sequence:
http://niralaakam.blogspot.in/2013/03/b ... der3d.html
~vanangamudi
ldo
Post by ldo »
Glad you figured it out so easily.
You should see the trouble I had with OpenCollada. :)
