Blender 2.5.2 plugin Scene Interchange 3ds max and other
silvio.falcinelli
Post by silvio.falcinelli »
this my alpha experiment plugin for import in Blender 2.5.2 full scene , geometry uv, material , texture, lights , animation of camera, and simplex animation of geometry with father children object, plugin for blender is opensource downloadable with encrypted script for 3d studio max,
next time I think also interchange viceversa Blender scene to 3ds Max, Lightwave, Maya
I extended parameter in obj export able for light and animation
for blender 2.5.3 beta 3, 3ds max 2010
upgrade 11-AUGUST-2010
http://www.rendering3d.net/sharing/blen ... der253.rar
plugin Blender 2.5.2 Import
blender2.5.2/.blender/scripts/io
http://www.rendering3d.net/sharing/scene_interchange.py
this native on LINUX , work also windows but not testing
script export for 3d studio max for 3ds max 8 , 9 , 2010
http://www.rendering3d.net/sharing/blen ... A_2010.zip
the video demonstration work also animation Father Children Parent
http://www.youtube.com/watch?v=pLsMzmaH05g
kikislater
Post by kikislater »
Is there an update to work with the last svn version => 2.56
Thank you
JaneGardner
Post by JaneGardner »
Many thanx)) Yes it's for the last version :P
silvio.falcinelli
Re: Blender 2.5.2 plugin Scene Interchange 3ds max and oth
Now rewrite for blender 2.5.9
for geometry use Collada .dae format (FIXED .dae file from max to blender)
Light:
Export Standard LIght, Mentalray Light, Vray Light, Ies light (for YAFARAY engine)
Material:
Standar, Mentalray arch, VrayMtl, VrayLight, and some mixed material
textures:
Bitmap image only
diffuse, bump, alpha mask, specular
aimation:
camera: free and target, position, rotation, dolly, lens zoom
gemetry: position scale rotation, parent children
light: position, rotation, energy
http://www.rendering3d.net/sharing/blen ... rchange.py
http://www.rendering3d.net/sharing/blen ... X_2010.mse
Video demo interchange in interior scene (400mb)
and demo for animation parameters
http://www.youtube.com/watch?v=Aft9BVIW1r0
demo for work in Linux and Windows at the same time
BUG blender import:
but not finish for Spot light type target no support animation rotation
(Spot light type FREE is ok also animation rotation)
BUG 3ds max export:
in DAE panel export must be set manually each time ANIMATION OFF
(because for animation use format mde in Interchange script)
SETTING recommend for export:
Y-UP or Z-UP is superfluous because in interchange import be automatic convert in Z-UP in any case of export
scale dimension 1=1 (mm), because in interchange import have true
system for rescale all scene
OFF animation
mkandy
Post by mkandy »
silvio.falcinelli wrote:Now rewrite for blender 2.5.9
Light:
Material:
textures:
Bitmap image only
aimation:
BUG blender import:
BUG 3ds max export:
OFF animation
Thanks for your post. I have been trying to import .dae file in blender 2.60. But i was not able to import in to blender. I have exported to .dae file using the script(BLENDER_INTERCHANGE_COLLADA_FIX_2010.mse) from 3dsmax 2010 by switching ON and OFF of DAE set off animation. But error repeats. I have attached the screen shot of the error. Kindly suggest how to proceed further.
Error
Errors found during parsing COLLADA document. Please see console for error log.
orhttp://i40.tinypic.com/19onb.jpg
FYI, just a box and camera are animated for 30 frames.
Regards,
Mani
ldo
Post by ldo »
Have you thought of putting this on a source repository site like GitHub? Would make it easier for others to collaborate with you on it, raise issues, contribute patches etc.
shamim.rtc
Post by shamim.rtc »
ldo wrote:Have you thought of putting this on a source repository site like GitHub? Would make it easier for others to collaborate with you on it, raise issues, contribute patches etc.
hi,
i downloaded 3DS MAX Scene Interchange from here
http://wiki.blender.org/index.php/Exten ... nterchange
thanks for this great addon, but I am still can not make it work for me
I am using 3dsmax2010, and blender2.6.2, but the export from 3dsmax is worked, but the import process will crash my blender2.6.2 and I tried 2.6.3. no luck
can you fix this ?
shamim hossain
