.B.blend
kvdman
.B.blend
Post by kvdman » Mon Aug 25, 2003 3:14 am
Ok, so can someone tell me where that file .B.blend is in WindowsXP? Cause I want to delete it, if infact it does hole the settings and doesn't get deleted when you uninstall blender according to: http://www.vrotvrot.com/support/showite ... aq_id=1354
I can't find it, and hopefully blender will work for me again once I delete it and reinstall...
theeth
Post by theeth » Mon Aug 25, 2003 4:07 am
It's somewhere in *Drive*:/Documents and Settings/*User*/
try making a search there.
- John Lennon
kvdman
not there...
Post by kvdman » Mon Aug 25, 2003 10:36 pm
Hi:
I have done a search, and looked manually all over for it, and the file is just not there...
Does anyone have any idea on how I can get Blender working on my computer again in Windows XP? I can't even start it without it crashing.
thnx
mcbridea
Post by mcbridea » Tue Aug 26, 2003 6:58 am
Try this: Make sure that you have show hidden files turned on (Tools --> folder options). Then do a search for the .b.blend file. Its located just like theeth said.
after the *User* folder look in the Application Data\Not a Number\Blender subfolder.
kvdman
I did that
Post by kvdman » Tue Aug 26, 2003 4:33 pm
I had hidden files showing...
i did a manual search, as well as a complete file search...
the file does exist in win98, but not in XP, I can guarantee it's not there...
It only appears if you change the default settings. That is, hit Ctrl + u, and then it will write it....
A guy wrote it in this forum here:
http://www.elysiun.com/forum/viewtopic.php?t=14974
but since, i couldn't even get blender started, i couldn't hit ctrl + u to write that file, that's why it didn't exist...
ascotan
Post by ascotan » Sat Aug 30, 2003 4:10 am
.B.blend is a file that just sets up the default user settings. If you delete it blender will function normally just with no user settings. Ctrl-U saves user settings in the .Blender folder (local to the .exe) on XP. The default install goes into the \'user'\application data\not a number\etc. folder. I don't think your crashing 'cause of the missing .blend file.
MacBlender
Post by MacBlender » Sat Aug 30, 2003 4:54 am
thats odd i found my .b.blend in my blender folder
i'm usign XP also
i just did a search for *.blend
