blender 2.23 question
mmoir
Post by mmoir » Fri Dec 19, 2003 12:14 am
I downloaded blender a quite a while ago and played with it and it was an interesting program . I am now on windows xp and blender 2.23 doesn't work the same as on windows 95.
The cursor creates a path of continuos cursors when you click and drag in the 3d windows and always creates this continuous path of the "cursor arrows" when you move in any of the other windows . Also , blender seems to run slower on Windows xp.
Does 2.3 correct this , I want to explore the game engine of blender so I was looking to stay in 2.23 or 2.25.
Thanks
Mike
mmoir
I found an answer
Post by mmoir » Fri Dec 19, 2003 3:02 am
In one of the forums here , there was a post about video card issues were I found a fix. I set hardware acceleration to none , which fixed the problem and blender seems to run fine.
Mike :)
Bernd
Post by Bernd » Sun Dec 21, 2003 12:34 pm
Hi mmoir,
I use serveral versions of Blender (2.25 to 2.31). They all runs under WinXP. Only one problem:
after a few seconds windows crashes total. First the mouse-cursur draws a line, then i saw a shadow behind, and then it crashes.
I turned of the shadow behind the mouse-arrow and everything works fine - and fast. Yes, without acceleration it works too, but very slow.
BTW who needs a shadow behind the arrow???
bye
mmoir
Post by mmoir » Mon Dec 22, 2003 2:38 am
Bernd,
How do you turn off the mouse shadow, I will look for that as well. Thanks
Mike
Bernd
Post by Bernd » Mon Dec 22, 2003 1:28 pm
my description bases on a german layout.
-start
-systemsteuerung
-darstellung und designs (on the right hand)
then on the left side you will see
-mouse
when you click it, a window appears
there is a menu called pointer (i think)
click it and then you will see at the bottom of the window
-pointer shadow? (i hope :-)
good luck
Bernd
mmoir
Post by mmoir » Mon Dec 22, 2003 2:32 pm
Bernd,
Thanks.
mmoir
Post by mmoir » Mon Dec 22, 2003 7:16 pm
Bernd,
I can't find this pointer menue. I am using blender 2.23 . I will keep hunting .
Mike
z3r0_d
Post by z3r0_d » Mon Dec 22, 2003 7:29 pm
mmoir wrote:Bernd,
Mike
it is in the mouse options in the control panel
on the cursors tab iirc
theeth
Post by theeth » Mon Dec 22, 2003 8:06 pm
This is not a Blender option btw, so the version number is irrelevent in this case.
- John Lennon
mmoir
Post by mmoir » Mon Dec 22, 2003 9:21 pm
Martin,
Once you said it wasn't blender related it was easy to find . Don't know if it speeds blender up though.
Thanks.
Mike
theeth
Post by theeth » Mon Dec 22, 2003 11:48 pm
I don't know if it will speed it up, but you'll have less artefacts in the interface.
- John Lennon
Users browsing this forum: No registered users and 5 guests
