particles (and some render stuff) (07/03/2004) - updated
rhinoguy
Post by rhinoguy »
Well, I just made a new mesh and used hash subdivide. It works the way I want it to now. So then I made a mesh tube, gave it particle deflection, and sent a stream of particles into it. Sweeeeet! This has GOT to be included in the next official release!!!!! :D
Apollux
Post by Apollux »
You know, that thing of the particles not working with armature is a real oldie... somebody should take care of it since it really cuts down the usefullness of the whole particles system.
rhinoguy
Post by rhinoguy »
You mean lattice, not armature (right?) Anyway, are you saying that this has been a known issue?! :o
Apollux
Post by Apollux »
No, I meaned ARMATURES. Last time I checked particles worked just fine when sent trough a lattice (but I never tryed lattice-deforming the emitter).
And yes, it is a well known issue that has been around since the moment armatures arrived (Blender 2.22), yet, nobody has looked into a way to fix it. If I recall correctly, it is caused because particles are calculated before the deformations, but I'm not a devolper
leon
Post by leon »
just a little bug fix update, see page!
ilac
Post by ilac »
Apollux wrote:No, I meaned ARMATURES. Last time I checked particles worked just fine when sent trough a lattice (but I never tryed lattice-deforming the emitter).
Might be solvable with a python script. If I recall correctly, you can access the transformation of an object via its matrix - even when it is being moved by an armature. So you would use python to extract the data and then write the data to the ipo's of the particle emitter. Unparent it from the armature (or use an empty attched to the armature as data source) Hit recalculate and render!
Apollux
Post by Apollux »
leon wrote:just a little bug fix update, see page!
What page? Am I missing something here?
ilac, thanks for the info.. I guess that now I have a good excuse to learn python :D
leon
Post by leon »
apollux- I have some bad news for you: you may not need to learn python after all! I've been taking a look at the particle emitter / armature bug this morning and thanks to Hos, it looks like this may be fixed!
For my simple test files, the emitter now moves with the armature.
I've committed the fix to Tuhopuu, and updated my binary on the first page. If you can test with files with complicated armatures etc, that would be great.
btw, I meant to say "page 1" rather than just "page"!!!
I haven't updated the code to take into account deflectors or attractors parented to armatures yet: due to the way particles are calculated, this may or may not be possible (could be a huge performance hit).
cheers
Leon
leon
Post by leon »
just a little update: there was a bug caused by the texture shadow map-to feature I put in (black lines every now and again on the render).
I've removed the texture shadow map option for now, and comitted to tuhopuu - the binary on the first page of this post is now updated.....
poutsa
Blend Files Tests wit Deflectors and Gravity Settings
Post by poutsa »
I have some Particle Test Files using Deflectors where can i Upload this files for Download...????
I dont have a Internet Site!
Ciao
vassilios
