bf-blender OSX 2.33 pre (30/04/04)
wavk
Post by wavk »
Hi, a fresh new OSX build with:
AO reflection/sky bug fix and other stuff:)
http://www.funnyfarm.tv/thelab/blender/blender.tar.gz
Money_YaY!
Post by Money_YaY! »
thankyou... Do you have a tuhopuu version to ?
JoOngle
Post by JoOngle »
Thanks for the OSX version.
Much appreciated!
/JoOngle
JoOngle
Post by JoOngle »
Ok, I've now tested your Mac os X version and have found some bugs quite similar to the test I performed on the windows version in the windows thread....but still...different bugs, the images speak for themselves.
Image 1 = original render. Blender Foundation 2.32 official release.
Image 2 = Rendered with the renderer found in this thread, Ambient Occlusion added, lights adjusted - nothing else.
Here's the render done with your release:
Notice the "green stuff" on the chair's raymirror reflective surface
Notice that the 3 glasses now are "yellowish" instead of just glass...
And...take a look at the reflection in the picture, the yellow glass...only the top are reflected...AND...the color creates yellowish stripes...? Weird...
I don't know...I'm a 3d'er...not a coder :) Anyway...thought I'd let you know.
Cheers,
/JoOngle
wavk
Post by wavk »
Hi JoOngle!
Yes I noticed it too, and I chatted about it yesterday with Ton, and he fixed it in no time :D It was a bug which had something to do with optimized sky/ao rendering or something similar. So it's fixed now, and maybe I'll find time this evening to upload it.
Money_YaY!, nope no tuhopuu version, although I am curious too about what's new in that release :)
Money_YaY!
wavk wrote:Hi JoOngle!
knothing yet, There is supost to be a patch for AQSIS soon
fossileyes
Post by fossileyes »
Is this build for Panther only?
The app. loads fine and I can open a .blend file, but when I render, the app. quits. Even if I try to render the default cube, it quits. I've had the same problem with other previous test builds. The bf official release of 2.32 a couple of months ago works just fine.
I'm running:
OSX 10.2.8
G3 Blue & White
350mhz
576 megs of ram
Thanks for any info you can provide.
Money_YaY!
fossileyes wrote:Is this build for Panther only?
I'm running:
OSX 10.2.8
G3 Blue & White
350mhz
576 megs of ram
something must have happened then as the panther builds were working on 10.2 a little bit ago
wavk
Post by wavk »
That's wierd. It was built on panther, but I don't know about jaguar... I might test my build this evening on jaguar, then we should know if it's either Jaguar or something else on your system.
cekuhnen
Post by cekuhnen »
all works here!
JoOngle
Post by JoOngle »
Ok guys, I'll be looking forward to the corrected version.
Meanwhile I'll do some experiments with the OSA set to 8 (and on)
and see if it makes any difference....needless to say..this scene is rather
demanding and are definately cooking my cpu's both on my Mac/Linux/windows machines...
Keep up the EXCELLENT work guys! I luv' ya all.
/S
JoOngle
Post by JoOngle »
/S
wavk
Post by wavk »
Hi fossileyes,
I just checked on osx jaguar and you're right, blender crashes when pressing f12. Very wierd. Maybe I can test some things this weekend, like compiling it on the jaguar machine...
Hi JoOngle,
I just uploaded the new version, at the same download location :D
fossileyes
Hi wavk,
Thanks for checking out the bug, I thought maybe something was wrong
on my system. On a related note, when pressing the Anim button, the same thing happens, Blender quits.
wavk
Post by wavk »
You should check out the new release, it's built for 10.2, so that should work:) But you probably already have it:)
