Relevant feature:
-new ui stuff.
-Merge of Blender/cvs 2005/01/15
-bugfixes.
-Hos' Tweak mode thingy. Very experimental.
-Now the image windows is still smooth to move when zoomed in!
-By popular request: trying a darker background colour in the 3D View. Is this satisfactory?
-Brought the lamp Z axis lines as a themeable option
-Can now hold shift while clicking on a slider bar to have the old slider behaviour (+/- 0.1).
Commit:
-phase
Log:
Offering a lame alternative for the standard ultravivid toolbox.
Set preferred method in the userprefs->view & controls section.
-hos
Log Message:
Log:
Post merge conflict resolution.
Log:
Added my cvs merge 'script' to cvs.
Log:
OK, looks like the merge didn't go as smoothly as I'd hoped.
Both the python menu thingy and the softbody panel thingy
were botched and wouldn't build ... these should be checked!
-theeth
Log:
Expanded on Hos' Tweak mode thingy. Very experimental.
When dragging with right mouse, releasing confirms (only way to cancel is with Esc).
When doing mouse gestures, releasing confirms (right mouse cancels are usual).
Added projection math for single axis constraints. Both this and the projection code for planar constraints act weird in perspective mode. Will have to involve the pers matrix to solve that, trying to figure out how.
-phase
Log:
Renamed the Lame Toolbox option to Easy Toolbox.
It sounded kinda... lame.
Log:
Minor tweak: changed the image window xof/yof from short to float, so view
translation is still smooth when zoomed in.
-broken
Log:
Also fixed a little prob where tall thin buttons weren't
drawn properly.
-broken
Log:
* Brought the lamp Z axis lines as a themeable option as proposed
by efbie. It's controlled by the lamp theme colour, alpha affects
the line's transparency. Default is not fully opaque.
* Little colour tweaks
-broken
Log:
* Fixed invisible border select box due to theme in image window
* Made the border select lines dotted, keeping in line with Ton's
changes in the 3D View (which are are much better than before)
Brecht, if you'd like to commit this stuff:
http://users.pandora.be/blendix/solidedges.png
that would be a huge improvement too
-broken
Log:
* Can now hold shift while clicking on a slider bar to have the old
slider behaviour (+/- 0.1). Shift was chosen since it's used for
the 'precision' changing values on number fields
-bjornmose
Log:
need this to get a nice MSVC6 scons build
A new build is available
