trying to build tuhopuu3 on linux box and i get the following build errors related to openal, i am running openal version 20050504.
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x10f): In function `MP3_Callback':
: undefined reference to `SMPEG_status'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x11e): In function `MP3_Callback':
: undefined reference to `SMPEG_play'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x14c): In function `MP3_Callback':
: undefined reference to `SMPEG_playAudio'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x18e): In function `MP3_Callback':
: undefined reference to `SMPEG_stop'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x19a): In function `MP3_Callback':
: undefined reference to `SMPEG_rewind'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x1ee): In function `MP3_Callback':
: undefined reference to `SMPEG_enableaudio'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x1fe): In function `MP3_Callback':
: undefined reference to `SMPEG_enablevideo'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x2ae): In function `alutLoadMP3_LOKI':
: undefined reference to `SMPEG_new_data'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x2be): In function `alutLoadMP3_LOKI':
: undefined reference to `SMPEG_wantedSpec'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x342): In function `alutLoadMP3_LOKI':
: undefined reference to `SMPEG_actualSpec'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x3c1): In function `alutLoadMP3_LOKI':
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x3cd): In function `alutLoadMP3_LOKI':
: undefined reference to `SMPEG_delete'
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x46c): In function `mp3bid_remove':
/usr/lib/libopenal.a(al_ext_mp3.o)(.text+0x478): In function `mp3bid_remove':
/usr/lib/libopenal.a(al_ext_vorbis.o)(.text+0x152): In function `Vorbis_Callback':
: undefined reference to `ov_read'
/usr/lib/libopenal.a(al_ext_vorbis.o)(.text+0x2ec): In function `VorbHandle_delete':
: undefined reference to `ov_clear'
/usr/lib/libopenal.a(al_ext_vorbis.o)(.text+0x3e2): In function `alutLoadVorbis_LOKI':
: undefined reference to `ov_open_callbacks'
/usr/lib/libopenal.a(al_ext_vorbis.o)(.text+0x3f8): In function `alutLoadVorbis_LOKI':
/usr/lib/libopenal.a(alsa.o)(.text+0x26): In function `openal_load_alsa_library':
: undefined reference to `snd_strerror'
/usr/lib/libopenal.a(alsa.o)(.text+0x32): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_info_sizeof'
/usr/lib/libopenal.a(alsa.o)(.text+0x3e): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_malloc'
/usr/lib/libopenal.a(alsa.o)(.text+0x4a): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_free'
/usr/lib/libopenal.a(alsa.o)(.text+0x56): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_close'
/usr/lib/libopenal.a(alsa.o)(.text+0x62): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params'
/usr/lib/libopenal.a(alsa.o)(.text+0x6e): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_any'
/usr/lib/libopenal.a(alsa.o)(.text+0x7a): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_get_buffer_size'
/usr/lib/libopenal.a(alsa.o)(.text+0x86): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_get_channels'
/usr/lib/libopenal.a(alsa.o)(.text+0x92): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_get_period_size'
/usr/lib/libopenal.a(alsa.o)(.text+0x9e): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_access'
/usr/lib/libopenal.a(alsa.o)(.text+0xaa): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_buffer_size_near'
/usr/lib/libopenal.a(alsa.o)(.text+0xb6): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_channels'
/usr/lib/libopenal.a(alsa.o)(.text+0xc2): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_format'
/usr/lib/libopenal.a(alsa.o)(.text+0xce): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_period_size'
/usr/lib/libopenal.a(alsa.o)(.text+0xda): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_periods'
/usr/lib/libopenal.a(alsa.o)(.text+0xe6): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_rate'
/usr/lib/libopenal.a(alsa.o)(.text+0xf2): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_set_rate_near'
/usr/lib/libopenal.a(alsa.o)(.text+0xfe): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_hw_params_sizeof'
/usr/lib/libopenal.a(alsa.o)(.text+0x10a): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_open'
/usr/lib/libopenal.a(alsa.o)(.text+0x116): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_nonblock'
/usr/lib/libopenal.a(alsa.o)(.text+0x122): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_prepare'
/usr/lib/libopenal.a(alsa.o)(.text+0x12e): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_readi'
/usr/lib/libopenal.a(alsa.o)(.text+0x13a): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_resume'
/usr/lib/libopenal.a(alsa.o)(.text+0x146): In function `openal_load_alsa_library':
: undefined reference to `snd_pcm_writei'
/usr/lib/libopenal.a(esd.o)(.text+0x2ec): In function `grab_write_esd':
: undefined reference to `esd_open_sound'
/usr/lib/libopenal.a(esd.o)(.text+0x303): In function `grab_write_esd':
: undefined reference to `esd_standby'
any tips? what version of openal is everone using?
nate d.
tuhopuu3 on linux openal build error
- Contact:
Hi Nate,
Your version of openal was compiled with extra libraries.
So you will need to link them in. It depends on the build system
for how you do this. If your using scons you need to edit config.opts
and find OPENAL_LIBRARY = ['openal'] and add in your extra libs, something like
OPENAL_LIBRARY = ['openal', 'smpeg', 'vorbis']
You may need some others...
If your using the Makefiles you will want to edit source/nan_link.mk
add add the extra libs Look for the -l(library)'s under your platform
and add -lsmpeg -lvorbis and any others you need.
