2.4 crease error
2.4 crease error
I think I have detected an error with the edge crease function. It doesn't work in the official 2.4 build. I select the edges I want to crease, press SHIFT+E and drag the mouse outwards. Is this the wrong way? I done it like that in 2.37A.
Submit your file to the bug tracker.Robin wrote:I have Windows XP. But it doesn't work. If you doesn't believe me I can mail it to you.
Also, some things you should mention:
- Did you remove your previous Blender install ?
- Did you install from exe or extracted from zip ?
- Are you using an older file with an object and loading it in 2.40 ?
Cheerz,
-- Rui --
How to use a Blender:
Put your model, rig, animation and textures in the Blender, turn the Blender on and wait for it to Render, then turn the Blender off and show it to your friends.
Have you installed to a different directory then the previous installed version ?Robin wrote:I did not remove my previous version. I installed from .exe. I am using an object I created only with 2.4. I don't know how to send the file to bug tracker.
This because the installer usually defaults to the same directory.
Anyway, register yourself here.
Then login and post your issue here.
At the bottom is a place to upload your file with the bug report.
Cheerz,
-- Rui --
