Blender as Universal Binary?
Quick question: Is anyone working on making a Universal Binary version of Blender? I am considering a new Macbook Pro, and Blender is important to me.
I would assume Blender would be relatively easy to port since it is designed in a very cross-platform way, and mostly relies on OpenGL, which is implemented natively into the new intel macs. Blender is not tied to a specific processor or any specific OS APIs.
Is anyone persuing this? If not, I suppose I could try compiling myself, but I'm not so good at that, so I don't expect any results.
-Bill
-Bill
Re: Blender as Universal Binary?
To build and test an Intel mac version, you need such a comp. unfortunately neither Ton or I intends to buy one shortly.William wrote:Quick question: Is anyone working on making a Universal Binary version of Blender? I am considering a new Macbook Pro, and Blender is important to me.
-Bill
If you are ready to do it, we will gladly accept the help
Now building an univ binary may be not that straight forward, there is a lot of places where we tested __APPLE__ def to check if we needed to do things big or small endians ways.
this will likely have to be changed
Blender Universal Binary testing
Depending on how things go this month, I may be able to test it on a lab of Intel iMacs. Does that help?
Re: Blender Universal Binary testing
if you can debug C code, yes. but you would be mostly on your own.jjjolton wrote:Depending on how things go this month, I may be able to test it on a lab of Intel iMacs. Does that help?
unless a coder has physical (or via ssh) access to an intel mac, resolving the hurdles is unprobable
I've ran blender on an intel mac through rosetta..works seamlessly and is a little slower than my iMac 1.8 G5. (Store model, so no builds/debugging from me). But I have an unrelated question - how can I run blender from the terminal and use the option switches? nothing I tried works. (like -b for background rendering).
Hi folks. I'm fairly new to Blender but I have a decent amount of experience writing C.
I've got a nice new MacBook Pro that I'm more than happy to use to help in getting universal binaries happening.
At the moment, I'm not really sure where to start - I'm about to download the source and have a dig around in it. Any suggested starting points - anyone else been using Xcode to build? et cetera.
Alright, I made a little progress.
Firstly I hacked nan_compile.mk inside the ifeq($(OS),darwin) conditional to provide correct -march flags depending on the setting of $CPU:
Individual files build fine now. I'll find out pretty quickly if pentium-m is the correct arch - if need be I'll just change it back to i386 for now.
The next problem is that I need a bunch of 3rd party libs to build - freetype etc. What the usual way people provide them on PPC Darwin? Via Fink?
Fink on Intel Darwin is prety low on packages at the moment, so they'll probably have to be built manually. Just wanted to see what people do about the libs in general before I go off in the wrong direction
ifeq ($(OS),darwin)
CC = gcc
CCC = g++
ifeq ($(CPU),i386)
CFLAGS += -pipe -fPIC -ffast-math -march=pentium-m
CCFLAGS += -pipe -fPIC
else
CFLAGS += -pipe -fPIC -ffast-math -mcpu=7450 -mtune=G5
endif
REL_CFLAGS += -O2
REL_CCFLAGS += -O2
CPPFLAGS += -D_THREAD_SAFE
NAN_DEPEND = true
OPENGL_HEADERS = /System/Library/Frameworks/OpenGL.framework
AR = ar
ARFLAGS = ruv
RANLIB = ranlib
ARFLAGSQUIET = ru
endif
WOW
That's great. I'm glad someone is making progress on this. I just got a MacMini Intel Core Duo, and am finding it increasingly difficult to get my workflow mac oriented. Unfortunately I have little programming experience, but would be glad to test your binaries on my system once you have something working.
Keep up the good work.
- Contact:
I'd be curious to know if pentium-m is correct! Please let me know what you find out?ben_h wrote:Individual files build fine now. I'll find out pretty quickly if pentium-m is the correct arch - if need be I'll just change it back to i386 for now.
I had good success running everything through darwinports: it compiles native on your machine, so assuming that's an Intel Mac (as mine is) it works just fine.ben_h wrote:The next problem is that I need a bunch of 3rd party libs to build - freetype etc. What the usual way people provide them on PPC Darwin? Via Fink?
Note that you'll need to get libiconv (that isn't immediatley obvious from the dependencies) and do some tweaking of the lib directory, but it can be made to work.
I've noticed, though, that SDL and OpenAL define some symbols identically, so I've yet to get OpenAL to work, but you can certainly compile without that.
Now to tackle Endian issues...
-Bischofftep
