Why can't i open .dsw and .dsp files for this release (with VC++6.0) ???
It tell me that it's not Developer Studio generated files ?????
Thanks for help !
* get the quicktime developer stuff,
and put it so that the folder
"QT6 SDK (Win)" is in the
same directory as the tuhopuu
blender directory
* checkout bf-blender
* steal the blender/lib directory from bf-blender
and put it in the tuhopuu blender directory
(make sure this directory is clean -- i.e., you
didn't try building bf-blender with it first).
* open blender/intern/make/msvc_6_0/intern.dsw
* go to the menu "Build->Set Active Configuration"
and set that to "build_install_all - Win32 Release"
* press the build button and watch it go
* open blender/projectfiles/creator/blendercreator.dsw
and set that to "blenderpublisher - Win32 Release"
You'll then find a blenderpublisher.exe in
blender/obj/windows ... it will run provided
that blender can find an fmod.dll
(use the one that came with the old blender
2.25 binary release).
I am using your instructions for compiling blender
and when I do the build_install_all win 32 release, it
starts to build put then at the very end, I get an error
that it cannot find Python. I am using python 2.2.2
and have verified that python.exe is on the path,
since I can execute it in any CMD (DOS window).
You need to go to the MSVC options where
you set up the directories MSVC uses. There is
one setting for where MSVC looks for executables.
Add the directory where your python executable
resides to that list of directories.
I found it under Options->Directories->Executables
and then included the python directory.
I tried first using python22, but then this caused some
errors, so I went back to python20 where I have Python 2.0.1
installed. Here is what I get. It now finds the python.exe file
under in c:\python20 correctly, and I reset all environment
variables to point here. Does this "config" error ring a bell?
Is it trying to recompile Python itself?
Linking...
Freezing Blender Python
Error: needed directory c:\python20\lib\python2.0\config not found
Use ``freeze.py -h'' for help
Error executing c:\windows\system32\cmd.exe.
I downloaded and built the python
source (2.2.2). I think doing that might
make it work .Please read the
directions in the python source,
and don't forget to point the
MSVC executable path to the
new python executable.
when installing Python from the exe, it forgets to instal some folders when they are not needed. Just create the folders that MSVC complains about, it will work correctly after that (even if the said folders are empty).
- John Lennon
I did what you suggested-made those previously
nonexistent directories within the
c:\python22 area. I did not put anything in the
directories--just created them. The build then went through
with 0 errors and 2 warnings.
Then, I tried to build blender using the
blender.dsw that was presumably just
constructed under
blender\projectfiles\blender, since I
didn't see a .dsw file under creator or
blenderpublisher directories.
now, I get the following errors. Any ideas? Have I missed
a step?
--------------------Configuration: BPY_frozen - Win32 Release--------------------
Build : warning : failed to (or don't know how to) build 'C:\cvs\blender\source\blender\bpython\frozen\M_vrml__utils__typeclasses.c'
Compiling...
frozen.c
frozen_extensions.c
M___future__.c
M_copy.c
M_copy_reg.c
M_gzip.c
M_mcf.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_mcf.c': No such file or directory
M_mcf__utils.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_mcf__utils.c': No such file or directory
M_mcf__utils__hier_rx.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_mcf__utils__hier_rx.c': No such file or directory
M_mcf__utils__hierobj.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_mcf__utils__hierobj.c': No such file or directory
M_mcf__utils__singletonlist.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_mcf__utils__singletonlist.c': No such file or directory
M_pprint.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_pprint.c': No such file or directory
M_repr.c
M_string.c
M_StringIO.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_StringIO.c': No such file or directory
M_types.c
M_vrml__utils.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_vrml__utils.c': No such file or directory
M_vrml__utils__collapse.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_vrml__utils__collapse.c': No such file or directory
M_vrml__utils__err.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_vrml__utils__err.c': No such file or directory
M_vrml__utils__namespace.c
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_vrml__utils__namespace.c': No such file or directory
fatal error C1083: Cannot open source file: 'C:\cvs\blender\source\blender\bpython\frozen\M_vrml__utils__typeclasses.c': No such file or directory
Error executing cl.exe.
I've had this prob with the bf-blender tree,
but not the tuhopuu tree. The work around
is to select the BPY_frozen project and in the
file view select the files it is complaining about
and press delete to remove them from the
project.
Incidentally, this error does not occur when
building bf-blender using Makefiles under
cygwin to control MSVC compilation.
(I hope to set a similar bulid scheme for
tuhopuu sometime real soon).
Good point. Rick Kimball told the same thing to me.
Got everything to compile and link.
Anyway, I gathered together all of the (weak) knowledge
that I have, and as explicitly as possible made a document
that details how the make process works from beginning
to end. I posted it at:
