Yes. That's an CVS version, thx- then all is clear.
But in 2.41 i have other problems becouse when i choose shaded view all looks to be ok, bu i also see textures(very blured), and when i chage to textured view all textures are gone. Don't look at background (rendered views). And light look like be in other position but is still in the same place.
I don't understand.
I have applied texture to this model, and mapping is to sphere.
And what face select mode had to display texture in textured view???
hit F in object select mode [or choose face select mode on the menu]
textures applied by slecting them in the image editor [while you have faces slected in face select mode] will show up in textured draw mode in the 3d view
But, btw is that only way to display texture in textured view?, not work on texture added without uv mapping (with only aded flat or spherical mapping)?
ZoltanPL wrote:But, btw is that only way to display texture in textured view?, not work on texture added without uv mapping (with only aded flat or spherical mapping)?
