Bf-Blender 2.5 /Windows : build updated when needed.
Do you mean Bkey to select and then ctrl-E in edit mode ?
I just checked this and it seems to work fine ...
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
Attention :
http://www.zoo-logique.org/3D.Blender/ is no more compatible
with Internet Explorer 6.xx . Use Mozilla, Firefox, flashget or
others tools to download .
09/30 version : softbodies with self collision
30/09 version : softbodies with self collision
I download it with IE and there is a problem when i try to unpack, but if i use 7zip, the archive seems to bee ok, and unpack without problems.
www.EmergencyArt.com
site under construction
I ran the w32blender1110 build on a pentium centrino laptop with windows XP home and mesh deformation in edit mode is very slow. To repeat this problem follow these steps:
1) select an object and enter edit mode.
2) add subsurf modifier with 1 level in edit mode
3) select a vertice and move it.
Hope this is enough information.
Sorry, i don't see any difference of speed with the previous version . But it is perhaps a problem with the graphic card .
OK, try this blend file. Go into edit mode and move a vertice around. Response is much slower compared to the production build.
http://markopuff.com/animations/slow.zip
hum, it looks like an heavy subdivision ...ericsh6 wrote:OK, try this blend file. Go into edit mode and move a vertice around. Response is much slower compared to the production build.
The original Blender 2.42 is really faster .
The problem also happens in other compilations for Window . You should make a bug report .
