TrackTo Constraint error
Hi all,
i've just compiled the latest svn blender and when i try to track a camera to an object it gives me core dump.
system: xubuntu 7.04
anyone experiment this?
thanks,
Paulo Gomes
thanks,
Paulo Gomes
hi aligorith,
i can't open almost all of my files, because i use the track to constraint to do the 'target camera', but i've tested with the default scene and when i try to track the camera to the cube it crashs.
if there is a way to know why it crashs, a log or a dump of some kind, please tell me how can i get it and i will send it to you.
thanks,
Paulo Gomes
thanks,
Paulo Gomes
1. What you need to do is to compile a debug build (i.e. a build with debugging symbols). The way to do this depends on the build system that you are using (i.e. scons, makefiles, CMake).
With scons, you just do:
2. Once you've got a debug build compiled, run gdb (a debugger) on the debug build.
3. Then type to start blender. Once blender is running, try to crash it...
4. In gdb, type to get a backtrace. Upload this backtrace
scons BF_DEBUG=1
gdb ./blender
run
4. In gdb, type
bt
ok, here is the result of the bt command in gdb:
#0 0x005c0013 in ?? ()
#1 0x086cfffc in BLI_ghash_lookup (gh=0x8e84840, key=0x4)
at source/blender/blenlib/intern/BLI_ghash.c:121
#2 0x0861770e in BKE_icon_get (icon_id=4)
at source/blender/blenkernel/intern/icons.c:270
#3 0x0841586f in icon_draw_mipmap (x=11.25, y=178.600006, icon_id=4,
aspect=1.21827412, miplevel=0, nocreate=0)
at source/blender/src/interface_icons.c:995
#4 0x08415b24 in BIF_icon_draw_aspect (x=11.25, y=178.600006, icon_id=4,
aspect=1.21827412) at source/blender/src/interface_icons.c:1049
#5 0x08415c0d in BIF_icon_draw_aspect_blended (x=11.25, y=178.600006,
icon_id=4, aspect=1.21827412, shade=0)
at source/blender/src/interface_icons.c:1070
#6 0x08379d65 in ui_draw_icon (but=0x9142b30, icon=ICON_FILESEL, blend=0)
at source/blender/src/interface_draw.c:217
#7 0x0837e9b3 in ui_draw_text_icon (but=0x9142b30)
at source/blender/src/interface_draw.c:1627
#8 0x08381d15 in ui_draw_but (but=0x9142b30)
at source/blender/src/interface_draw.c:2433
#9 0x08165eab in uiDrawBlock (block=0x9127358)
at source/blender/src/interface.c:994
#10 0x081958da in uiDrawBlocksPanels (sa=0x90efe08, re_align=0)
at source/blender/src/interface_panel.c:1507
---Type <return> to continue, or q <return> to quit---
#11 0x0841e1e1 in drawbutspace (sa=0x90efe08, spacedata=0x90f3200)
at source/blender/src/butspace.c:781
#12 0x08281cbd in scrarea_do_windraw (area=0x90efe08)
at source/blender/src/spacetypes.c:128
#13 0x0819a04f in screen_swapbuffers_REDRAW (sc=0x90ef890)
at source/blender/src/swapbuffers.c:114
#14 0x0819a684 in screen_swapbuffers () at source/blender/src/swapbuffers.c:285
#15 0x08301de7 in screen_dispatch_events ()
at source/blender/src/editscreen.c:1247
#16 0x083027c5 in screenmain () at source/blender/src/editscreen.c:1509
#17 0x0815d872 in main (argc=1, argv=0xbfe65244)
at source/creator/creator.c:707
Re: TrackTo Constraint error
paulo_gomes wrote:Hi all,
thanks,
Paulo Gomes
I have had this ghappen. I did a quick trial and error and I removed it, I cannot remember how.. but it worked.
Just press buttons until you find it.
Rammstein.
Blender.
My site.
Doctor who.
Stiv-Winner of the *removed* award.
The world is set.
Blender.
My site.
Doctor who.
The world is set.
Just press buttons until you find it? Sheesh. If we had an award for Funny Useless Posts, you would have just won.Liam.blend wrote: I have had this ghappen. I did a quick trial and error and I removed it, I cannot remember how.. but it worked.
*ahem* Say again: Your A funny little *removed* arn't ya?stiv wrote:Just press buttons until you find it? Sheesh. If we had an award for Funny Useless Posts, you would have just won.Liam.blend wrote: I have had this ghappen. I did a quick trial and error and I removed it, I cannot remember how.. but it worked.
I was trying to help. *Mods-Let him read this first*
I HAVE HAD THIS HAPPEN! I DID PRESS BUTTONS and IT DID WORK.
*removed* Some people are thick.
Stiv-Winner of the funny *removed* award.
Rammstein.
Blender.
My site.
Doctor who.
The world is set.
Blender.
My site.
Doctor who.
The world is set.
Bottom line, Liam.blend: if you use naughty words and say offensive things, your posts *will* get removed. Keep it up and *you* will get removed. Let's all play nice.
I have no doubt you 'fixed' your problem by just pressing some buttons . However, as programmers, we believe in reproducible results and fixing problems. "Just press buttons" is in no way reproducible. As an example, given 10 buttons and 3 presses, you have 1000 separate combinations to try. At the very least, give the poor guy as hint as to which buttons to press! Life is too short.
Go back and read the thread. They are talking about a problem with the code, a bug. We fix bugs by isolating them and changing the code. I don't doubt you were trying to be helpful, but saying "just press some buttons" is useless advice.
