I tried to export CFLAGS="-g -O2 -I/usr/include -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.5.sdk" CXX=gcc CXXFLAGS="-g -O2 -I/usr/include -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.5.sdk"
qhull compiles pretty well, but when it gets to the Freetype libraries things go bad... anything I may be missing? Here is the output:
ake all in extern/bFTGL/src
g++ -c -Wall -Wno-reorder -DUSE_SUMO_SOLID -pipe -fPIC -funsigned-char -fno-strict-aliasing -DNDEBUG -O2 -D_THREAD_SAFE -I../include -I/Users/rlangschultz/blender/blender/../lib/darwin-9.1.0-i386/freetype/include -I/Users/rlangschultz/blender/blender/../lib/darwin-9.1.0-i386/freetype/include/freetype2 -I/System/Library/Frameworks/OpenGL.framework FTBitmapGlyph.cpp -o /Users/rlangschultz/blender/blender/obj/darwin-9.1.0-i386/extern/ftgl/FTBitmapGlyph.o
In file included from FTBitmapGlyph.cpp:3:
../include/FTBitmapGlyph.h:5:22: error: ft2build.h: No such file or directory
../include/FTBitmapGlyph.h:6:10: error: #include expects "FILENAME" or <FILENAME>
../include/FTBitmapGlyph.h:7:10: error: #include expects "FILENAME" or <FILENAME>
In file included from ../include/FTBitmapGlyph.h:10,
../include/FTGlyph.h:5:10: error: #include expects "FILENAME" or <FILENAME>
../include/FTGlyph.h:6:10: error: #include expects "FILENAME" or <FILENAME>
In file included from ../include/FTGlyph.h:8,
../include/FTBBox.h:5:10: error: #include expects "FILENAME" or <FILENAME>
../include/FTBBox.h:7:10: error: #include expects "FILENAME" or <FILENAME>
In file included from ../include/FTBBox.h:10,
../include/FTPoint.h:5:10: error: #include expects "FILENAME" or <FILENAME>
../include/FTPoint.h:6:10: error: #include expects "FILENAME" or <FILENAME>
../include/FTPoint.h:39: error: expected ‘,’ or ‘...’ before ‘&’ token
../include/FTPoint.h:39: error: ISO C++ forbids declaration of ‘FT_Vector’ with no type
../include/FTPoint.h: In constructor ‘FTPoint::FTPoint(int)’:
../include/FTPoint.h:40: error: ‘ft_vector’ was not declared in this scope
../include/FTBBox.h: At global scope:
../include/FTBBox.h:49: error: expected `)' before ‘glyph’
../include/FTGlyph.h:31: error: expected `)' before ‘glyph’
../include/FTGlyph.h:65: error: ‘FT_Error’ does not name a type
../include/FTGlyph.h:81: error: ‘FT_Error’ does not name a type
../include/FTBitmapGlyph.h:31: error: expected `)' before ‘glyph’
FTBitmapGlyph.cpp:5: error: expected `)' before ‘glyph’
make[2]: *** [/Users/rlangschultz/blender/blender/obj/darwin-9.1.0-i386/extern/ftgl/FTBitmapGlyph.o] Error 1
make[1]: *** [all] Error 1
make: *** [all] Error 1
Building x86_64 on Leopard
Hi rlang. Any success with your 64-bit build on Leopard? I just recently switched to a Mac Pro and would dearly love to be able to compile a 64-bit version for this platform. I keep running into issues with xvidcore when trying to build it.
Perhaps you could give me some pointers as to what libraries you're using, and perhaps the config for whatever build system you're using? Would be hugely appreciated.
Undefined symbols:
"_xvid_V_Pass_8_mmx", referenced from:
_xvid_QP_Funcs_mmx in libextern_xvidcore.a(qpel.o)
"_MBFieldTest_mmx", referenced from:
_MBFieldTest_mmx$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_dequant_mpeg_intra_mmx", referenced from:
_dequant_mpeg_intra_mmx$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_sse2_os_trigger", referenced from:
_sse2_os_trigger$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_xvid_H_Pass_8_mmx", referenced from:
"_xvid_H_Pass_Avrg_8_Add_mmx", referenced from:
_xvid_QP_Add_Funcs_mmx in libextern_xvidcore.a(qpel.o)
"_dev16_sse2", referenced from:
Okay, I'm trying to build the current SVN version here. Using the default SCons darwin configuration, which so far as I can tell is would use the bundled ffmpeg. Looks like it's failing during linking. Something to do with the xvid libraries. Here's a snippet :
there's several hundred lines of the same pointer reference problems which follow this, all of them in libextern_xvidcore.a
gcc -o /Users/craig/blender/svn/build/darwin/bin/blenderplayer -fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Carbon -framework AGL -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework QuickTime -u __dummy -u _PyMac_Error -framework System -framework Python -framework OpenGL /Users/craig/blender/svn/build/darwin/source/creator/dynamic_buildinfo.o /Users/craig/blender/svn/build/darwin/lib/libgp_ghost.a /Users/craig/blender/svn/build/darwin/lib/libgp_common.a /Users/craig/blender/svn/build/darwin/lib/libbf_string.a /Users/craig/blender/svn/build/darwin/lib/libbf_ghost.a /Users/craig/blender/svn/build/darwin/lib/libbf_blenkernel.a /Users/craig/blender/svn/build/darwin/lib/libnodes.a /Users/craig/blender/svn/build/darwin/lib/libblender_ONL.a /Users/craig/blender/svn/build/darwin/lib/libbf_decimation.a /Users/craig/blender/svn/build/darwin/lib/libbf_blenloader.a /Users/craig/blender/svn/build/darwin/lib/libbf_blenpluginapi.a /Users/craig/blender/svn/build/darwin/lib/libbf_imbuf.a /Users/craig/blender/svn/build/darwin/lib/libbf_avi.a /Users/craig/blender/svn/build/darwin/lib/libbf_bloutines.a /Users/craig/blender/svn/build/darwin/lib/libbf_converter.a /Users/craig/blender/svn/build/darwin/lib/libbf_sumo.a /Users/craig/blender/svn/build/darwin/lib/libbf_ketsji.a /Users/craig/blender/svn/build/darwin/lib/libextern_solid.a /Users/craig/blender/svn/build/darwin/lib/libextern_qhull.a /Users/craig/blender/svn/build/darwin/lib/libbf_bullet.a /Users/craig/blender/svn/build/darwin/lib/libbf_common.a /Users/craig/blender/svn/build/darwin/lib/libbf_dummy.a /Users/craig/blender/svn/build/darwin/lib/libbf_logic.a /Users/craig/blender/svn/build/darwin/lib/libbf_rasterizer.a /Users/craig/blender/svn/build/darwin/lib/libbf_oglrasterizer.a /Users/craig/blender/svn/build/darwin/lib/libbf_expressions.a /Users/craig/blender/svn/build/darwin/lib/libbf_scenegraph.a /Users/craig/blender/svn/build/darwin/lib/libbf_moto.a /Users/craig/blender/svn/build/darwin/lib/libbf_soundsystem.a /Users/craig/blender/svn/build/darwin/lib/libbf_kernel.a /Users/craig/blender/svn/build/darwin/lib/libkx_network.a /Users/craig/blender/svn/build/darwin/lib/libbf_ngnetwork.a /Users/craig/blender/svn/build/darwin/lib/libbf_loopbacknetwork.a /Users/craig/blender/svn/build/darwin/lib/libextern_bullet2dynamics.a /Users/craig/blender/svn/build/darwin/lib/libextern_bullet2linmath.a /Users/craig/blender/svn/build/darwin/lib/libextern_bullet2collision.a /Users/craig/blender/svn/build/darwin/lib/libbf_guardedalloc.a /Users/craig/blender/svn/build/darwin/lib/libbf_memutil.a /Users/craig/blender/svn/build/darwin/lib/libbf_bmfont.a /Users/craig/blender/svn/build/darwin/lib/libbf_yafray.a /Users/craig/blender/svn/build/darwin/lib/libbf_blenlib.a /Users/craig/blender/svn/build/darwin/lib/libextern_libavformat.a /Users/craig/blender/svn/build/darwin/lib/libextern_libavcodec.a /Users/craig/blender/svn/build/darwin/lib/libextern_libswscale.a /Users/craig/blender/svn/build/darwin/lib/libextern_libavutil.a /Users/craig/blender/svn/build/darwin/lib/libbf_cineon.a /Users/craig/blender/svn/build/darwin/lib/libbf_ftfont.a /Users/craig/blender/svn/build/darwin/lib/libbf_dds.a /Users/craig/blender/svn/build/darwin/lib/libbf_openexr.a /Users/craig/blender/svn/build/darwin/lib/libbf_quicktime.a /Users/craig/blender/svn/build/darwin/lib/libextern_ftgl.a /Users/craig/blender/svn/build/darwin/lib/libbf_dna.a /Users/craig/blender/svn/build/darwin/lib/libbf_readblenfile.a /Users/craig/blender/svn/build/darwin/lib/libblenkernel_blc.a /Users/craig/blender/svn/build/darwin/lib/libextern_x264.a /Users/craig/blender/svn/build/darwin/lib/libextern_libmp3lame.a /Users/craig/blender/svn/build/darwin/lib/libextern_xvidcore.a -L/Users/craig/blender/svn/build/darwin/lib -L/usr/lib -L/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/config -L/System/Library/Frameworks/OpenGL.framework/Libraries -L/Users/craig/blender/svn/lib/darwin-8.x.i386/sdl/lib -L/Users/craig/blender/svn/lib/darwin-8.x.i386/jpeg/lib -L/Users/craig/blender/svn/lib/darwin-8.x.i386/png/lib -L. -L. -L/Users/craig/blender/svn/lib/darwin-8.x.i386/openexr/lib -L/Users/craig/blender/svn/lib/darwin-8.x.i386/gettext/lib -L/Users/craig/blender/svn/lib/darwin-8.x.i386/freetype/lib -L/Users/craig/blender/svn/lib/darwin-8.x.i386/openal/lib -ljpeg -lpng -lz -lfreetype -lintl -lopenal -liconv -lIex -lHalf -lIlmImf -lImath -lIlmThread -lSDL -lstdc++ -lSystemStubs
Install file: "release/plugins/texture/Makefile" as "/Users/craig/blender/svn/install/darwin/plugins/texture/Makefile"
Install file: "release/plugins/texture/tiles.c" as "/Users/craig/blender/svn/install/darwin/plugins/texture/tiles.c"
Install file: "release/text/blender.html" as "/Users/craig/blender/svn/install/darwin/blender.html"
Install file: "release/text/BlenderQuickStart.pdf" as "/Users/craig/blender/svn/install/darwin/BlenderQuickStart.pdf"
Install file: "release/text/copyright.txt" as "/Users/craig/blender/svn/install/darwin/copyright.txt"
Install file: "release/text/GPL-license.txt" as "/Users/craig/blender/svn/install/darwin/GPL-license.txt"
Install file: "release/text/Python-license.txt" as "/Users/craig/blender/svn/install/darwin/Python-license.txt"
Install file: "release/text/release_244.txt" as "/Users/craig/blender/svn/install/darwin/release_244.txt"
Undefined symbols:
"_yv12_to_bgra_mmx", referenced from:
_yv12_to_bgra_mmx$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_dequant_h263_inter_3dne", referenced from:
_dequant_h263_inter_3dne$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_sad8bi_3dne", referenced from:
_sad8bi_3dne$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_xvid_H_Pass_Add_16_mmx", referenced from:
"_dequant_mpeg_inter_3dne", referenced from:
_dequant_mpeg_inter_3dne$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_dequant_h263_inter_mmx", referenced from:
_dequant_h263_inter_mmx$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_dequant_h263_inter_xmm", referenced from:
_dequant_h263_inter_xmm$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_sse8_8bit_mmx", referenced from:
_sse8_8bit_mmx$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_dequant_h263_intra_3dne", referenced from:
_dequant_h263_intra_3dne$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_transfer_16to8copy_3dne", referenced from:
_transfer_16to8copy_3dne$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_interpolate8x8_halfpel_h_3dne", referenced from:
_interpolate8x8_halfpel_h_3dne$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_dequant_mpeg_intra_3dne", referenced from:
_dequant_mpeg_intra_3dne$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_quant_h263_inter_sse2", referenced from:
_quant_h263_inter_sse2$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_transfer_8to16subro_mmx", referenced from:
_transfer_8to16subro_mmx$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_interpolate8x4_halfpel_v_3dn", referenced from:
_interpolate8x4_halfpel_v_3dn$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_interpolate8x8_halfpel_h_3dn", referenced from:
_interpolate8x8_halfpel_h_3dn$non_lazy_ptr in libextern_xvidcore.a(xvid.o)
"_xvid_H_Pass_Avrg_16_mmx", referenced from:
I applied following diff to my code it worked
Index: extern/xvidcore/build/generic/configure
--- extern/xvidcore/build/generic/configure (revision 17438)
+++ extern/xvidcore/build/generic/configure (working copy)
@@ -4052,6 +4052,13 @@
PREFIX="-DPREFIX"
MARK_FUNCS=""
+ darwin*)
+ { echo "$as_me:$LINENO: result: darwin" >&5
+echo "${ECHO_T}darwin" >&6; }
+ NASM_FORMAT="macho"
+ PREFIX="-DPREFIX"
+ MARK_FUNCS=""
esac
AS="$chosen_asm_prog"
PREFIX="-DPREFIX"
MARK_FUNCS=""
+ darwin*)
+ PREFIX="-DPREFIX"
+ MARK_FUNCS=""
esac
Sometime I wish I was a little kid again
