Python - 3DS Import Problem
hopbunny
Post by hopbunny » Wed Aug 19, 2009 7:42 am
Hi Everyone!
I'm a newbie and I just installed Blender 2.40 on my Windows XP PRO computer. I can import a .3Ds object just fine but I would like to know if its possible to import a .3Ds file in Blender and export it as .TGA file so I can use it on my virtual world in Second Life.
fantasmo
Post by fantasmo » Wed Oct 07, 2009 3:42 pm
Hello,
I tried the thing with "installing Blender 2.40". My 3ds-file... which should actually be a cat... was opened, but it was just a simple cube.
This is the file I used, i got from a free model library:
http://rapidshare.com/files/289834516/7 ... l.3ds.html
Previously trying to open it in a new Blender version brought these mistakes:
line 882, in load_3ds process_next_chunk(file, current_chunk, importedObjects. IMAGE_SEARCH)
line 464, in process_next_chunk process_next_chunk(file, new_chunk, importedObjects, IMAGE_SEARCH)
line 807, in process_next_chunk temp_dat=file.read(calcsize(binary_format))
Memory Error
I hope somebody can help, because I'm a complete 3D beginner. Thank you!
Menian Lee
importing blender files in blender
Post by Menian Lee » Fri Dec 04, 2009 11:00 pm
What's the trick?
I had an external teacher on Blender and he directed me to this forum and topic, when I couldn't import blender objects in blender.
I'm on XP, Blender 2,49b, Python 2.6.4.
When I try to import blender file, I choose 3ds as format, and in the console the message is Fatal Error: Not a valid 3ds file
If this is not a valid file format for blender files, what it is? There is no .blender format to choose from in import options.
Post by stiv » Fri Dec 04, 2009 11:13 pm
A .blend is not a 3ds file, simple as that. For native blender files use File->Open. No trick involved.
Menian Lee
Post by Menian Lee » Sat Dec 05, 2009 10:59 am
File - open, just open in the same window and removes the previous info
Shift + F1 worked for me - thanks to
http://blenderartists.org/forum/showthread.php?t=112268
May be I should have searched more before writing here
Cheers
Post by stiv » Sat Dec 05, 2009 5:22 pm
It would not hurt to take a quick skim thru the manual or one of the intro guides. This stuff is pretty basic to using Blender.
ganna
Post by ganna » Fri Jan 15, 2010 11:08 am
I'm a newbie and I'm trying to open a 3Ds file (converted using the Autodesk fbx converter into 3ds from an fbx exported in Maya) but I am getting the same error message - Not a valid 3ds file.
dvdbrander
Post by dvdbrander » Thu Jul 22, 2010 11:56 pm
bumping a good oldie :P
well, same problem, but I have 1 more.
mu 3ds_import file, line 203 is:
OBJECT_MESH = long('0x4100',16); # This lets us know that we are reading a new object
I have blender v2.49.2.
What do I have to do? (wew, this doesn't sounds like good english, I'm dutch :P)
Darkmatterial
Importing .3ds files into blender-2.49b-win64-python26
Post by Darkmatterial » Thu Oct 18, 2012 1:39 pm
Hi folks,
I am just a begginer in blender, I have a problem when importing .3ds files into blender -2.49b for windows, every time it gives me the following message: "a hole phyton installation not found" does anyone have a clue of what can I do next?
Thanks a lot
Post by stiv » Thu Oct 18, 2012 4:59 pm
For Blender 2.49 (old blender), you need to install Python. Use the version Blender asks for at startup. - usually 2.5 or so. Other versions will not work.
Note that new Blender (2.64) comes with its own copy of Python 3.
Darkmatterial
Post by Darkmatterial » Thu Oct 18, 2012 6:34 pm
stiv wrote:For Blender 2.49 (old blender), you need to install Python. Use the version Blender asks for at startup. - usually 2.5 or so. Other versions will not work.
Thanks a lot man I will try that!
