Two F-Curve Animations to one mesh.
Carpetfizz
Post by Carpetfizz »
I am currently making a game. I used the logic bricks to make the mesh play a short F-Curve animation on Left Click. I want to add a separate animation to the same mesh, so it will play the new F-Curve on Right Click. How do I go about doing the second animation for the one mesh?
Thanks!
SolarLune
Post by SolarLune »
The only way to do this I know of would be to put one animation on a certain key-frame length and put the second on a second keyframe length. For example, animation 1 would be from frame 1 - 50 and animation 2 from frame 100 - 150. Then, you would select which animation frame set to play. Otherwise, use an armature and make actions for it (you can make and trigger more than one).
Check out my blog of game design and BGE tutorials at http://solarlune-gameup.blogspot.com/
Carpetfizz
Thank you very much! I would have never thought of this, because I kind of ignored the "frame" buttons on the logic modules.
SolarLune
Post by SolarLune »
No prob. There's a lot of features and functions that the BGE has access to - learning about them can really make a game easy to work with.
