227 crashes
shadow
227 crashes
Post by shadow »
simple rendering, one spot with max shadow buffer, rotating fan...
and:
SEgmentation fault
is it ram or swap??
The box said: "Requires Windows 95 or better"
So I installed Linux...
IoN_PuLse
Post by IoN_PuLse »
System specs? .blend? Operating system? Blender release (i see you have 2.27, but if you are running a distro of linux, then dynamic or static) etc....more info = more chance of fixing/resolving problem for you :)
shadow
Post by shadow »
ugh,
I think it is a fault of poor cooling. Mozilla has started to crash either. Anyway, I have put bigger fan and will watching what will happen.
Blender static
OS: Debian Woody
256 MB RAM (yes i know it's too small)
shadow
Post by shadow »
with this myscene.blend file, 226 and 227 crashes sometimes even Xserver. I checked RAM-it is OK,
in the render process swap isn not in use.
I have an integrated Graphics - SIS
What's wrong?
meestaplu
Post by meestaplu »
You might want to try testing the RAM with the program available (free) at www.memtest86.com . If Mozilla has also started crashing, you may have a memory problem on your hands, and those usually don't show up on the puny POST check that the BIOS conducts on startup. My system kept crashing unexpectedly; it turned out to be dirty RAM. It really was physically dirty -- simply blowing the dust off fixed the problem.
Good luck --
Matt
shadow
Post by shadow »
memtest crashes with sebmentation fault output. :(
I cleaned the ram and add an extra cooler for the processor and memory.
Maybe iit is a fault of the X sever?
Or maybe its because of use maximum shadow buffer size?
soletread
Post by soletread »
What SIS version is your GPU?
I have a SIS.
This is more than likely your problem. Without a doubt my SIS 315 is not at all compatible with blender. And I doubt whether any other SIS is either.
Try disable your onboard GPU and slot in another one.
Or try a really old version of the driver. Your problem will clear up but not much 3D acceleration anywhere.
Just a thought. Use it, dont use it..... :P
