I select two vertices and press the "G". However, Blender create some new vertices instead of moving the selected ones. I feel very confused.
PS, I am in the edit mode and the grab tools works fine before.
Need Help! Unable to use Grab correctly.
Re: Need Help! Unable to use Grab correctly.
Did you mess with key settings?Yumilong wrote:...the grab tools works fine before.
I think it must be some key i press incidently.MatejMo wrote:Did you mess with key settings?Yumilong wrote:...the grab tools works fine before.
So, I save my project and create a new file using loading the factory setting.
Then, everything works fine. I can use grab tool property.
But as if i reload my project, select vertices and press "g", grab tools still unable to work in the right way.
