Rendering in orthographic projection
BloB
Post by BloB » Fri Mar 07, 2003 1:59 pm
Hi.
Is there anyone who can confirm that some rendering features are disabled when the camera is performing an orthographic projection ? For instance no mist is rendered whereas in a 'standard 3d" projection, I see the mist perfectly.
The underlying question is : can I produce an image of the Z-buffer of a scene in ortho-projection? I tried to used the mist for this. Is there another recommended way?
BloB.
Jamesk
Post by Jamesk » Fri Mar 07, 2003 3:34 pm
For some reason it sounds perfectly logical that mist doesn't work in ortho mode... Don't ask me why, but it feels like one of those zen things... That didn't help of course...
BloB
Post by BloB » Fri Mar 07, 2003 3:57 pm
I wonder what 'some' reason might be...
You still get a Z-distance from the camera, you still can do Z-buffering, the faces are still rendered almost the same way. There seems to be also a problem with texture coordinates in ortho-projection (not UV-edited but the other ones).
It's just the projection matrix that changes (theoretically).
BloB.
BloB
Well, well, well...
Post by BloB » Wed Mar 12, 2003 10:29 am
Now that the sources are open, anyone can have a peek. Can anyone explain me why the mist is treated differently in orthographic projection?
Namely, in v2.25 sources, in file source/blender/blenkernel/intern/world.c,
line 191, I can read:
Code: Select all
if(cam->type==CAM_ORTHO) {
	/* dit is maar ongeveer */
	R.wrld.miststa+= (float)fabs(R.viewmat[3][2]);
Has anyone a clue on this one ? The starting position of the mist is 'pushed' further by a distance found in the view projection matrix ?
BloB.
Users browsing this forum: No registered users and 3 guests
