How can I copy UV maps from one model to another?
vipercaleb1
Post by vipercaleb1 »
How do you copy uv maps from one model to another?
like in this tutorial:
http://www.gamasutra.com/view/feature/2 ... php?page=2
Like this:
Any ideas? Thanks
psullie
Post by psullie »
hi
what exactly are you trying to do? In general UV maps are linked to the geometry of the object and not transferrable.
If its just the texture you want then you could use the bake to selected option http://wiki.blender.org/index.php/Doc:Manual/Textures/
Paul
manish_toons
Re: How can I copy UV maps from one model to another?
Post by manish_toons »
There are two methods to do this but, I found the easiest way to do is,
First select the model which you want to be unwrap then select the unwrapped model..
Go to
script window >> script menu >> object >> UV from Active
For this model's mesh (poly count) should be same....
Manish
Voxel Animation Studios, India
mahendra.g@voxelstudios.in
manish_toons@aol.in
psullie
Post by psullie »
Thanks Manish
I wasn't aware of that.
Cheers
Paul
raskolnikow
Post by raskolnikow »
I am encountering a similliar problem. Does anyone have an idea on how to archieve that in Blender 2.6x ?
Ingfrith
Post by Ingfrith »
raskolnikow wrote:Hi,
For Blender 2.6x this option is under Object menu at the bottom of the 3D window.
As before, select the model which you want to be unwrap then select the unwrapped model:
Object --> Make Links (Shortcut Ctrl L) ---> Transfer UV Layouts
