Segmentation fault for 2.5 svn
palz
Post by palz » Sat Mar 20, 2010 12:06 pm
Hi all
i'm experiencing problems running blender 2.5 on linux
i get
Code: Select all
Blender 2.52 (sub 0) Build
Build: "2010-03-09" "16:58:31" "linux2" "dynamic"
argv[0] = ./blender
argv[1] = -d
read file
  Version 251 sub 0
ordered
 OBCube
 OBLamp
 OBCamera
Segmentation fault
in both precompiled and freshly built-from-svn versions
what could be the problem?
appultaart
Post by appultaart » Sat Mar 27, 2010 12:48 am
I experience the same problems (Ubuntu 64-bit) as described by first poster; both for the svn version (currently svn 27780) and for the 2.50 alpha 2 downloaded from blender.org.
The program starts, I see the window being built (window border, top window where 'Blender' is written and the min-max-close buttons. Then the Segmentation fault comes in.
When I run the svn-compiled file with gdb, I get the following:
$gdb ./blender
(gdb) start
Temporary breakpoint 1 at 0x6c8ca0
[Thread debugging using libthread_db enabled]
Temporary breakpoint 1, 0x000000000006c8ca0 in main()
(gdb) continue
Continuing.
Program received signal_SIGSEGV, Segmentation Fault.
0x00000000000e316a6 in GHOST_SetTitle ()
(gdb) backtrace
#0 0x0...0e316a6 in GHOST_SetTitle ()
#1 0x0...06cac50 in wm_windows_title ()
#2 0x0...06cb607 in wm_window_add_ghostwindows()
#3 0x0...06d62f4 in WM_check ()
#4 0x0...06d77c0 in WM_read_homefile ()
#5 0x0...06cbbac in WM_init ()
#6 0x0...06c8e1a in main ()
(gdb) quit
Any ideas?
appultaart
Post by appultaart » Sat Mar 27, 2010 1:13 am
Update:
this appears not to be a Blender-related issue.
I noticed as of this afternoon, Compiz is not working and cannot be activated. The pre-compiled blender 2.50 alpha2 is working fine on an older version of Ubuntu.
I upgraded a bunch of Xserver and GTK+ packages after lunch - this is when my Compiz stopped working and Blender most likely also... Will look into fixing that...
stiv
Post by stiv » Sat Mar 27, 2010 2:06 am
Occasionally, development versions of Blender have problems with the startup file. Try deleting the .B25.blend file in your home directory.
Also worth noting if there are display problems - Compiz (and compositing window managers, in general) often have problems with OpenGL applications like Blender. Turning off Compiz/Aero/KDE4 desktop effects often helps.
appultaart
Post by appultaart » Sat Mar 27, 2010 4:05 am
[SOLVED] @stiv: your remark made me check whether the 'glxgears' program was working; it's a nice indicator if my video card is set up correctly. 'glxgears' was not working.
So, I booted into console mode; uninstalled and re-installed the binary NVidia driver I was already running (195.36.15) from command line. After reboot, openGL works again, Compiz and Blender 2.5 and all. Great!
palz
Post by palz » Fri Apr 02, 2010 7:06 pm
today i updated from svn
just the same picture
compiz is off on my system i believe, cause there are no window-effects or smth like that
glxgears work nice
stiv
Post by stiv » Fri Apr 02, 2010 11:13 pm
1) delete your ~/.B25.blend
2) run blender in the debugger to see where it is crashing
palz
Post by palz » Mon Apr 05, 2010 1:28 am
the .B25.blend was not there, maybe because i had never successfully run blender on this OS installation.
Code: Select all
(gdb) run
Starting program: /home/cd/Загрузки/blender/install/linux2/blender
Program received signal SIGSEGV, Segmentation fault.
0x00eb7f8d in ?? () from /lib/ld-linux.so.2
Code: Select all
(gdb) backtrace
#0  0x00eb7f8d in ?? () from /lib/ld-linux.so.2
#1  0x00ebc326 in ?? () from /lib/ld-linux.so.2
#2  0x00ec1fc0 in ?? () from /lib/ld-linux.so.2
#3  0x08580212 in GPU_state_init ()
#4  0x082bc50c in wm_window_add_ghostwindows ()
#5  0x082b2560 in WM_check ()
#6  0x082c1973 in WM_read_homefile ()
#7  0x082c442a in WM_init ()
#8  0x082b0ec3 in main ()
actually i'm not yet very familiar with debugging process, what some other useful information can i pull out here? just give me a hint.
DrJamesWright
Post by DrJamesWright » Sun Jul 04, 2010 11:50 am
stiv wrote:1) delete your ~/.B25.blend
I did this and now it works fine.
palz
Post by palz » Mon Jul 05, 2010 5:00 pm
i still have no success in running even the latest svn version 252 sub 5
the output is just hte same as in my first post
stiv
Post by stiv » Mon Jul 05, 2010 7:17 pm
Can you run other OpenGL applications like glxgears?
palz
Post by palz » Tue Jul 06, 2010 10:13 am
yes, glxgears works fine
teejay
Post by teejay » Sun Aug 01, 2010 6:25 pm
palz
Post by palz » Fri Sep 03, 2010 3:38 pm
I've got still no success running the latest SVN.
I can build with no errors but when i run i get the same segmentation fault as described above.
stiv
Post by stiv » Fri Sep 03, 2010 7:07 pm
This part looks like the culprit:
If you are compiling blender yourself, build it debug and you can see exactly where in the source code it is failing. It appears to be graphics related.
