i would like import a file in a blender plugin, which is in the same directory
so i 've written the import, but when i use a class of the file imported, i have this mistake:
NameError: name 'Md3Frame' is not defined
How to resolve this problem?
to include python files in an other script in Blender
add the path to this module to the python path variable
Martin
Code: Select all
import sys
sys.path.append("c:/blah/blah/blah/")
- John Lennon
- John Lennon
it doesn't work
Here is an example of what i would like doing
my file "module.py"
class Class:
def __init__ (self):
pass
my file "main.py"
import module
import sys
sys.path.append("/home/info/An-01-02/levimond/blender/plugins")
myClass = Class ()
i want execute "main.py" in Blender but i get this mistake:
File "main.py.001", line 6, in ?
NameError: name 'Class' is not defined
So, how can i resolve this problem ?
my file "module.py"
class Class:
pass
my file "main.py"
import module
import sys
myClass = Class ()
use either this
or this
Martin
Code: Select all
from module import *
myClass = Class()
Code: Select all
import module
myClass = module.Class()
- John Lennon
- John Lennon
