Render all cameras python script (2.56beta)
baze
Post by baze »
I could find a python script for Blender 2.56Beta that would render all or selected cameras in a batch mode. So I made it my self and just want to share it here.
Just run like this:
blender -b your_file.blend -P render_all_cameras.py
... or to render just cameras containing text "east":
blender -b your_file.blend -P render_all_cameras.py cameras=east
----- render_all_cameras.py -------------
Code: Select all
# Render all cameras or cameras containing text given with command line argument "cameras".
# Example:
# Let's say test.blend file contains cameras "east.01", "east.02", "west.01", "west.02"
# By executing command "blender -b your_file.blend -P render_all_cameras.py" all 4 cameras will be rendered.
# Command "blender -b your_file.blend -P render_all_cameras.py  cameras=east" will render "east.01" and "east.02" cameras.
# Command "blender -b your_file.blend -P render_all_cameras.py  cameras=01" will render "east.01" and "west.01.02" cameras.
import bpy, bgl, blf,sys
from bpy import data, ops, props, types, context
print("\nThis Python script will render your scene with all available cameras")
print("or with camera(s) matching command line argument 'cameras'")
print("")
print("Usage:")
print("Render all cameras:")
print("blender -b your_file.blend -P render_all_cameras.py\n")
print("Render only matching cameras:")
print("blender -b your_file.blend -P render_all_cameras.py  cameras=east\n")
cameraNames=''
# Loop all command line arguments and try to find "cameras=east" or similar
for arg in sys.argv:
    words=arg.split('=')
    if ( words[0] == 'cameras'):
     cameraNames = words[1]
print('rendering cameras containing [' + cameraNames + ']')
print('\nPrint Scenes...')
sceneKey = bpy.data.scenes.keys()[0]
print('Using Scene['  + sceneKey + ']')
# Loop all objects and try to find Cameras
print('Looping Cameras')
c=0
for obj in bpy.data.objects:
    # Find cameras that match cameraNames
    if ( obj.type =='CAMERA') and ( cameraNames == '' or obj.name.find(cameraNames) != -1) :
      print("Rendering scene["+sceneKey+"] with Camera["+obj.name+"]")
      # Set Scenes camera and output filename
      bpy.data.scenes[sceneKey].camera = obj
      bpy.data.scenes[sceneKey].render.file_format = 'JPEG'
      bpy.data.scenes[sceneKey].render.filepath = '//camera_' + str(c)
      # Render Scene and store the scene
      bpy.ops.render.render( write_still=True )
      c = c + 1
print('Done!')
danielbaggio
Re: Render all cameras python script (2.56beta)
Post by danielbaggio »
Thank you a lot, man!!!
djay86
Post by djay86 »
baze I need it this script.. Thanks alot taking time to help!!
botgirl
Post by botgirl »
hey there,
i'm a total nOOb with blender, but i'm forced right now to use this batch cam render script, since i have a lot of characters, which need to be rendert from different camera angles.
right now i'm hitting the render button, wait for some hours, get the next cam, hit the render again a.s.o.
so this script is perfect for me.
unfortunately i'm too new to know my way around python, tried severel things the internet suggestet, but couldnt get the script to run..
would u be so kind to post a how-to-use this script ?
that would be great ....
thank u!
stiv
Post by stiv »
The BPy API has changed some in the last two years, so the script will likely need some rework to get it functional again.
Just off the top of my head, one way to deal with this is to make copies of the scene with everything linked except for the camera. Then you can just render all the scenes from the command line.
anachronist
Post by anachronist »
Hey,
I just wanted to share my (slightly different) version of the script. Now it runs with my version of Blender (v2.66.1) and renders the complete animation (I simply modified two lines)...
Code: Select all
# Example:
print("")
print("Usage:")
cameraNames=''
c=0
      #bpy.data.scenes[sceneKey].render.file_format = 'JPEG'
      bpy.data.scenes[sceneKey].render.filepath = '//camera_' + str(c) + '_'
      bpy.ops.render.render( animation=True )
      c = c + 1
print('Done!')
