blender very slow on my pc , any way to improve ?
umen
Post by umen » Mon May 21, 2012 6:55 am
Hello all
i installed the latest blender and previous version also
and its working very very slow . i have average pc here is DoctorGL output of my pc if its helps:
its intel 2 cpu with 4 giga ram running xp 32 bit
can i somehow make it faster ?
Video Card Vendor: Intel
Renderer: Intel Broadwater G
OpenGL Version: 1.4.0 - Build 6.14.10.4670
GLU Version: 1.2.2.0 Microsoft Corporation
Current pixel format: 6
Pixel Formats supported by this video card
# Type Flags Buf Type Color(R-G-B-A) Z-Depth Stencil Accum(R-G-B-A)
1 ICD 00000024 SGL RGBA 32 (8-8-8-8) 0 0 0(0-0-0-0)
2 ICD 00000025 DBL RGBA 32 (8-8-8-8) 0 0 64(16-16-16-16)
3 ICD 00000024 SGL RGBA 32 (8-8-8-8) 16 0 0(0-0-0-0)
4 ICD 00000025 DBL RGBA 32 (8-8-8-8) 16 0 64(16-16-16-16)
5 ICD 00000024 SGL RGBA 32 (8-8-8-8) 24 8 0(0-0-0-0)
6 ICD 00000025 DBL RGBA 32 (8-8-8-8) 24 8 64(16-16-16-16)
7 GEN 0000007C SGL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
8 GEN 0000007C SGL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
9 GEN 00000465 DBL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
10 GEN 00000465 DBL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
11 GEN 0000007C SGL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
12 GEN 0000007C SGL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
13 GEN 00000465 DBL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
14 GEN 00000465 DBL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
15 GEN 0000007C SGL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
16 GEN 0000007C SGL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
17 GEN 00000465 DBL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
18 GEN 00000465 DBL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
19 GEN 00000078 SGL RGBA 24 (8-8-8-0) 32 8 64(16-16-16-0)
20 GEN 00000078 SGL RGBA 24 (8-8-8-0) 16 8 64(16-16-16-0)
21 GEN 00000078 SGL RGBA 24 (8-8-8-8) 32 8 64(16-16-16-16)
22 GEN 00000078 SGL RGBA 24 (8-8-8-8) 16 8 64(16-16-16-16)
23 GEN 00000078 SGL CI 24 (8-8-8-0) 32 8 0(0-0-0-0)
24 GEN 00000078 SGL CI 24 (8-8-8-0) 16 8 0(0-0-0-0)
25 GEN 00000078 SGL RGBA 16 (5-5-5-0) 32 8 32(11-11-10-0)
26 GEN 00000078 SGL RGBA 16 (5-5-5-0) 16 8 32(11-11-10-0)
27 GEN 00000078 SGL RGBA 16 (5-5-5-8) 32 8 32(8-8-8-8)
28 GEN 00000078 SGL RGBA 16 (5-5-5-8) 16 8 32(8-8-8-8)
29 GEN 00000078 SGL CI 16 (5-5-5-0) 32 8 0(0-0-0-0)
30 GEN 00000078 SGL CI 16 (5-5-5-0) 16 8 0(0-0-0-0)
31 GEN 00000078 SGL RGBA 8 (3-3-2-0) 32 8 32(11-11-10-0)
32 GEN 00000078 SGL RGBA 8 (3-3-2-0) 16 8 32(11-11-10-0)
33 GEN 00000078 SGL RGBA 8 (3-3-2-8) 32 8 32(8-8-8-8)
34 GEN 00000078 SGL RGBA 8 (3-3-2-8) 16 8 32(8-8-8-8)
35 GEN 00000078 SGL CI 8 (3-3-2-0) 32 8 0(0-0-0-0)
36 GEN 00000078 SGL CI 8 (3-3-2-0) 16 8 0(0-0-0-0)
37 GEN 00000078 SGL RGBA 4 (1-1-1-0) 32 8 16(5-6-5-0)
38 GEN 00000078 SGL RGBA 4 (1-1-1-0) 16 8 16(5-6-5-0)
39 GEN 00000078 SGL RGBA 4 (1-1-1-8) 32 8 16(4-4-4-4)
40 GEN 00000078 SGL RGBA 4 (1-1-1-8) 16 8 16(4-4-4-4)
41 GEN 00000078 SGL CI 4 (1-1-1-0) 32 8 0(0-0-0-0)
42 GEN 00000078 SGL CI 4 (1-1-1-0) 16 8 0(0-0-0-0)
OpenGL extensions found for the current pixel format
GL_ARB_depth_texture
GL_ARB_fragment_program
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_point_parameters
GL_ARB_shadow
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3
GL_ARB_texture_env_crossbar
GL_ARB_transpose_matrix
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_window_pos
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_cull_vertex
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_multi_draw_arrays
GL_EXT_packed_pixels
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture_compression_s3tc
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_lod_bias
GL_EXT_texture_filter_anisotropic
GL_EXT_texture3D
GL_3DFX_texture_compression_FXT1
GL_IBM_texture_mirrored_repeat
GL_NV_blend_square
GL_NV_texgen_reflection
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_WIN_swap_hint
umen
also more info , found out how to get systeminfo from blende
Post by umen » Mon May 21, 2012 9:15 am
= Blender 2.63 (sub 0) System Information =
Blender:
version 2.63 (sub 0), revision b'46461:46487M'. b'Release'
build date: b'2012-05-10', b'12:08:39'
platform: b'Windows:64bit'
binary path: 'D:\\Program Files\\Blender Foundation\\Blender\\blender.exe'
build cflags: b'/nologo /Ob1 /J /W1 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp -O2 -DNDEBUG -DWIN32 -D_CONSOLE
-D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE'
build cxxflags: b'/nologo /Ob1 /J /W1 /Gd /wd4018 /wd4244 /wd4305 /wd4800 /wd4065 /wd4267 /we4013 /openmp /EHsc -O2 -DNDEBUG -DWIN32 -
D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE'
build linkflags: b'/SUBSYSTEM:CONSOLE /MACHINE:IX86 /STACK:2097152 /INCREMENTAL:NO /LARGEADDRESSAWARE /NODEFAULTLIB:msvcrt.lib
/NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib'
build system: b'SCons'
Python:
version: 3.2 (r32:88445, Mar 4 2011, 02:13:51) [MSC v.1500 32 bit (Intel)]
paths:
'D:\\Program Files\\Blender Foundation\\Blender\\2.63\\scripts\\addons'
'D:\\Program Files\\Blender Foundation\\Blender\\2.63\\scripts\\startup'
'D:\\Program Files\\Blender Foundation\\Blender\\2.63\\scripts\\modules'
'D:\\Program Files\\Blender Foundation\\Blender\\2.63\\python'
'D:\\Program Files\\Blender Foundation\\Blender\\python32.zip'
'D:\\Program Files\\Blender Foundation\\Blender\\2.63\\python\\DLLs'
'D:\\Program Files\\Blender Foundation\\Blender\\2.63\\python\\lib'
'D:\\Program Files\\Blender Foundation\\Blender'
'D:\\Program Files\\Blender Foundation\\Blender\\2.63\\scripts\\addons\\modules'
'C:\\Documents and Settings\\meiry@dm-imcs\\Application Data\\Blender Foundation\\Blender\\2.63\\scripts\\addons\\modules'
Directories:
scripts: ['D:\\Program Files\\Blender Foundation\\Blender\\2.63\\scripts']
user scripts: None
datafiles: 'C:\\Documents and Settings\\meiry@dm-imcs\\Application Data\\Blender Foundation\\Blender\\2.63\\datafiles\\'
config: 'C:\\Documents and Settings\\meiry@dm-imcs\\Application Data\\Blender Foundation\\Blender\\2.63\\config\\'
scripts : 'C:\\Documents and Settings\\meiry@dm-imcs\\Application Data\\Blender Foundation\\Blender\\2.63\\scripts\\'
autosave: 'C:\\Documents and Settings\\meiry@dm-imcs\\Application Data\\Blender Foundation\\Blender\\2.63\\autosave\\'
tempdir: '/tmp\\'
FFmpeg:
'avcodec':' ''53, 60, 100'
'avdevice':' ''53, 4, 100'
'avformat':' ''53, 31, 100'
'avutil':' ''51, 34, 101'
'swscale':' '' 2, 1, 100'
OpenGL
renderer: 'Intel Broadwater G'
vendor: 'Intel'
version: '1.4.0 - Build 6.14.10.4670'
extensions:
'GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture'
'GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_shadow'
'GL_ARB_texture_border_clamp GL_ARB_texture_compression'
'GL_ARB_texture_cube_map GL_ARB_texture_env_add'
'GL_ARB_texture_env_combine GL_ARB_texture_env_dot3'
'GL_ARB_texture_env_crossbar GL_ARB_transpose_matrix'
'GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos'
'GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate'
'GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint'
'GL_EXT_compiled_vertex_array GL_EXT_cull_vertex'
'GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays'
'GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color'
'GL_EXT_separate_specular_color GL_EXT_shadow_funcs'
'GL_EXT_stencil_two_side GL_EXT_stencil_wrap'
'GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add'
'GL_EXT_texture_env_combine GL_EXT_texture_lod_bias'
'GL_EXT_texture_filter_anisotropic GL_EXT_texture3D'
'GL_3DFX_texture_compression_FXT1 GL_IBM_texture_mirrored_repeat'
'GL_NV_blend_square GL_NV_texgen_reflection GL_SGIS_generate_mipmap'
'GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_WIN_swap
stiv
Post by stiv » Mon May 21, 2012 6:31 pm
Depends on what 'slow' means. Rendering performance depends on the CPU. Modeling depends on the graphics subsystem.
Blender uses OpenGL for all its drawing. Some operating systems come with rather lame OpenGL drivers. Things to do:
Update the video drivers from the manufacturer's site.
Turn off eye candy window managers and themes. Transparency and poor video drivers are natural enemies.
umen
the GUI is very slow
Post by umen » Tue May 22, 2012 8:01 am
when i install the 2.49 version it is very fast , very !
stiv
Post by stiv » Tue May 22, 2012 7:46 pm
Try playing with Window Draw Mode in User Prefs.
robertolo
Post by robertolo » Sat May 26, 2012 9:27 pm
I have the same problem and nothing worked so far. I am going to try what you guys advise.
stiv
Post by stiv » Sun May 27, 2012 8:52 am
Don't use Microsoft's OpenGL
