Dynamically Generating Menus
welford
Post by welford » Sun Sep 30, 2012 7:42 am
I have a custom menu defined similarly to this:
Code: Select all
class W3DMenu(bpy.types.Menu):
	bl_label = "W3D"
	bl_idname = "W3D_MT_menu"
	def draw(self, context):
		layout = self.layout
		# file export
		layout.operator(".w3d_test", text="Test")
.w3d_test exports my models/anim. I want to be able to generate the menu dynamically and have a .w3d_test for the model and each animation contained within the file. Is is possible for me to pass a parameter to .w3d_test, i mean something like this:
Code: Select all
	layout.operator(".w3d_test",  parameter="model", text="Test")
	for action_key in bpy.data.actions:
		layout.operator(".w3d_test",  parameter=action_key, text="Test")
Thanks for any help,
CoDEmanX
Post by CoDEmanX » Mon Oct 01, 2012 4:00 pm
yes, you can pass parameters. First, you need to add properties to the class:
Code: Select all
   bl_label = "W3D"
   your_parameter = bpy.props.StringProperty()
   and_another = bpy.props.IntProperty()
      # file export
then pass the arguments like:
Code: Select all
   layout.operator(".w3d_test", text="Test").your_parameter = "model"
      layout.operator(".w3d_test", text="Test").your_parameter = action_key
in case you wanna pass multiple arguments, do it like this:
Code: Select all
   for i, action_key in enumerate(bpy.data.actions):
      props = layout.operator(".w3d_test", text="Test")
      props.your_parameter = action_key
      props.and_another = i
welford
Post by welford » Sun Nov 18, 2012 7:00 am
Thank you very much :)
Users browsing this forum: No registered users and 3 guests
