Finding the name of an object file I imported?
Jarmade
Post by Jarmade » Sat Nov 03, 2012 10:36 pm
I want to do some operations on the mesh after i have imported it, like renaming it, but i can't find a way to get the object name
Here is how i imported the object:
Code: Select all
import bpy
folder = "D:/cg/export"
file = "test.obj"
foo = bpy.ops.import_scene.obj(filepath=(folder + "/" + file))
print(foo)
# foo = {'FINISHED'}
# so how do i access the object i just imported?
CoDEmanX
Post by CoDEmanX » Mon Nov 05, 2012 10:16 am
importers should clear previous user selection and select all newly imported objects, thus you should be able to access them via
bpy.context.selected_objects
Jarmade
Post by Jarmade » Mon Nov 05, 2012 6:04 pm
CoDEmanX wrote:importers should clear previous user selection and select all newly imported objects, thus you should be able to access them via
thanks, this is what i ended up doing, although it seems messy
Code: Select all
bpy.ops.import_scene.obj(filepath=fullpath)
imported = bpy.context.selected_objects[0]
print(imported.name)
ldo
Post by ldo » Sun Nov 25, 2012 3:34 am
The basic problem is that operators represent user actions, not really low-level functions. What you want is a separate API call for invoking .obj import that has no UI dependencies.
