ShapeKey keyframe only animates selected object
KoviRobi
Post by KoviRobi »
Hi!
This is what I have done:
* I have made a shape key
* I have pressed "i" in the ShapeKey editor, for a particular setting, i.e. 0
* I have moved a few frames forward
* I have moved the setting to 1 and pressed "i" again, to animate
* The object animates as expected
* I have done this to a different object
* Only the currently selected object animates, the previous one does not.
This is what may be the problem
Note: I have tries replacing "key_blocks['Lifting_rotating'].value" with "bpy.data.shape_keys['Key.001'].key_blocks['Lifting_rotating'].value" but that did not work. Any suggestions?
Thank you!
