bf-blender / windows (2004/01/05)
I am using the windows system Environment variable settings. Are you saying that I don't need to use the Windows Environment "PATH" variables? Should I only use the YFexportdir in the userdefault window in Blender? I not sure if I understand you correctly?eeshlo wrote:JA-forreal:
You have set the path in in YFexportdir in the userdefault window in Blender?
The system path is not used at all, it doesn't matter to the export, only to yafray.
The path should be the full path to the yafray temporary export directory, but probably without the end slash (which could cause problems) so in your case something like 'c:\yafray\blender'.
This can be editted in the code though, I can imagine this will confuse some others as well.
Thanks Eeshlo!
You gave a simple solution to setting the new Blender and Yafray export builds Yafray program path. In the drop down menu I added the link to the Yafray rendering software in the "YFexport:" setting.
I set the "YFexport:" to g:\YafRay\- where Yafray is installed. It works!
I hope that this helps other Windows users to test out the new Blender software with Yafray Exporting.
Blend on!
Blend on!
Thanks eeshlo this works!eeshlo wrote:JA-forreal:
Thanks, this works!eeshlo wrote:JA-forreal:
