Render Text. Problem
MauLencinas
Post by MauLencinas »
Hello everyone! i'm a little confussed, i'm started and improved some text
compositing, and render of course, but here a problem appears when text is
rendered, a little deformation or triangles appearn on the surface of text ,
anyone have the explain for solved this?
http://i46.tinypic.com/vkl01.jpg
Thx!
Darth_Revan
Post by Darth_Revan »
Is it Text or Mesh? If it isn't mesh, you might try converting it to mesh (alt-c) then going into edit mode and recalculating the normals. Also if it is mesh, you could select the whole thing (a) and remove doubles (w, then select "remove doubles")
