I'm rather new to blender and I've been going (slowly at that..) through the tutorials that are out there. In one them I'm creating a window and it says to press F9 to get to the edit buttons and then to set the extrusion to 3.00,..... when i pressed the f9 key i do get the edit buttons but i dont see an extrusion setting am i doing something wrong? and how do i set it.
thanks in advance,
atomcode
setting the extrusion to 3.00
Not sure what you mean. You have to be in edit mode to see half of the panels (for a mesh). This panels system was introduced in 2.30 and the tutorial may be slightly outdated. Now, if you extrude vertices, you can limit the extrusion to full units by holding [ctrl], there is a extrude dup setting in editbuttons, etc. But I don't know what advice to give you.
I suggest you post a more detailed description of your problem at www.elysiun.com in the Q&A Forum. That's the users community, this forum is mostly for Blender development. Good luck!
