bf-blender / Windows (2004/09/26)
Doogs
Post by Doogs »
Yeah well all these bugs, you now see why its a testing build and not official ;)
RonC
ElBarto
Post by ElBarto »
When Cilp Z Buffer is on there are some problems with selecting edges, most of them couldn't be selected. If Cilp Z Buffer off anything works fine.
Falgor
Post by Falgor »
Thank you for these new features. So cool, guys! :o
God bless you. :)
oyster
Post by oyster »
Thank you for the new features. I think the "Subdivision surface draw" is a big approach to iso lines in SILO :lol: :
Iso Lines >>
Silo's subdivision surfaces now use iso line display and selection,. This means that only the edges descended from edges on the control mesh show up on the subdivided mesh.
Moreover, you can select the iso edges/faces/vertices directly and edit your subdivided mesh directly from the iso surface. Several options allow you to customize the iso line functionality.
thoro
Post by thoro »
Wow, the new Zbuffer clipped selection mode is very useful - and the Optimal draw subsurfs mode looks better than ever. Thank you so much!
pildanovak
Post by pildanovak »
the additions are great, especially the new select modes.
But somtimes the button for z-buffer selection disappers(??)
jesterKing
Site Admin
Post by jesterKing »
pildanovak wrote:the additions are great, especially the new select modes.
The zbuffer selection is available only in solidmode
/Nathan
pildanovak
another bug- edge-loop select in edge mode- if you select 2 colinear loops, also the edges which connect them are selected.
... and the same with poly loops
Crawl
Post by Crawl »
Hmm i've found something.
Added 2 Arealights, both the same setup: Shadows True, Samples 2, Noise.
But one of the Arealight shadows isnt noised. :shock:
Look:
Yfkar
Post by Yfkar »
This looks really promising! This is what I've been waiting for! It's pretty difficult to select an edge in the optimal subsurf mode but that doesn't matter at this stage. Wooooo!
SamAdam
Post by SamAdam »
how about adding more information to the transform properties based on selection method:
face: midpoint or meanpoint, area
edge: two endpoints, length
yamyam
Post by yamyam »
UV/FaceSelectMode works wrong, some faces are flipped. AFAIK, this problem has already been in 9/24 bf-windows build.
I don't know that ton(or other coder) is going to fix it or remove that mode, but I report it.
*** Edit ***
Sorry, I'm stupid. It's due to see the new monkey. :oops:
*** Edit ***
Dani
Post by Dani »
When I select four edges around one face, blender selects the face... same thing if I select four vertices... ie. if I extrude i'll extrude the face and not the (edges/verts)
This is not how I expect it to behave... if a select four edges and extrude them, I expect it to extrude the edges, not the face... I think this is the whole point in having edge/face distinction... no?
Or did i miss something?
Dani
Bellorum
Post by Bellorum »
You're not alone:) It's been brought up. There's also a proposal by broken here:
http://mke3.net/blender/etc/mesheditrewrite/mesh01.html
Dani
Post by Dani »
oh allright ;)
I guess the "Shift+R and friends selection doesn't work in zbuff mode" problem is a known one too...
what else? I found display glitches from place to place...
ie. when, in edit mode, you do an "Edge: Delete" in the F9 panel the seam is still draw until you "tabtab".
Creases seem to be working wrong though i need further testing...
Finally theres an ultimate (but big) problem due to the multiple selection modes.
I made a proposal here
http://www.blender.org/modules.php?op=m ... pic&t=4678
the discussion ended short when eric told me the three selection modes could be active at a time... I was sooo happy! But acutally, it's quite messy... selections mix up! This needs to be fixed!
Dani
