2.37 Layer Buttons in Editmode
Auralis
Post by Auralis »
Please please,
can we have the layer select buttons back in edit mode?
I used them quiet heavily for hiding and showing different parts of my model while editing another part of it. They where very usefull imo and should not have been removed.
kxs
Post by kxs »
i agree. please put it back
gabio
Post by gabio »
This is from the commit log:
ton:
- in EditMode, the layer buttons get hidden... the amount of icons in
3d header grows to fast.
I want to see all button. and though if I want to change layer, I just enter exit editmode.
Auralis
Post by Auralis »
Well, i don't have a problem with the number of buttons, and switching to object, edit mode just to show/hide layers is more work then it was before, for imo no good reason.
fligh
Post by fligh »
Learn to use 1-0 and Alt 1-0 on the keypad.
Auralis
Post by Auralis »
And this helps in this case how exactly?
Not at all.
slikdigit
Post by slikdigit »
they are hotkeys to change the layer... only problem there is for laptop users who have emulate numpad on- they lose this ability.
It may be that the intersection of the set of users with emulate numpad on and the set of users who switch layers during edit mode is empty, though.
SirDude
Post by SirDude »
Workaround I use for laptop stuff...
Make multiple Screen's and use cntrl arrow keys to switch between
them. (Also nice for switching 3d views) Takes a little bit to set it up but works.
Auralis
Post by Auralis »
hrm, ok this works, but the visible layers buttons would still provide a visual feedback on the operation and the layer visibility at a present point.
however, the use of alt, shit, 1-0 is imo more compilcated then just clicking on the layers i want, especialy with layers over number 5, since that would requiere severe ffinger knoting or leaving the mouse, therefore again interrupting the workflow.
The layer button window is what i VERY much prefere to have.
Maybe as a hideable part, like with the little triangle that hides the menus in the headers.
joeri
Post by joeri »
SirDude wrote:Workaround I use for laptop stuff...
Yes this is all much better than have some buttons in the header.
Pfff... typical case of distoying users workflow because of bad ideas of what to do with the growing number of buttons. Guys, removing them is the worst of all the solutions !
kxs
Post by kxs »
and beside, there are NOT to many buttons in Edit Mode. You`re talking like they couldn`t fit into window
Bellorum
Post by Bellorum »
kxs wrote:and beside, there are NOT to many buttons in Edit Mode. You`re talking like they couldn`t fit into window
Split up the screen in smaller windows and say that again :roll:
kxs
Post by kxs »
:? you`re right. never thought of that as I`m working on only one window.
But if you use few windows then is there a difference if the layers are hidden or invisible (if it would be on the right)? And with one window it makes a difference.
Beside, in your case, isn`t it better to hit Ctrl+Upper Arrow and then change layer then not having that oportunity at all?
As it comes for me, I use number keys to change layer. But when I need to set few layers visible it is easier to use layer menu
Pierre-Luc_Auclair
Post by Pierre-Luc_Auclair »
I've already said it and I say it again: there is no use to have the modes text shown; icons are there to do that. It's just taking too much space for nothing.
Delta
Post by Delta »
why dont we have show/hide trangle that can hide or show not only the layer buttons but for any number of buttons, like Auralis said..
maybe something like the hide/show icons button on an xp taskbar?
Regards,
~Delta
