Erwin is currently fixing the commit for other platforms, hopefully he will finish it soon.
LetterRip
Multitexture/GLSL
I use GNU/Linux Debian sid. My nVidia card is GeForce 6800 GT and driver version 1.0-8178. I use gcc version 4.1.0.
This patch fixed same build problem:
Code: Select all
Index: source/gameengine/Ketsji/KX_BlenderMaterial.cpp
RCS file: /cvsroot/bf-blender/blender/source/gameengine/Ketsji/KX_BlenderMaterial.cpp,v
retrieving revision 1.4
diff -u -p -r1.4 KX_BlenderMaterial.cpp
--- source/gameengine/Ketsji/KX_BlenderMaterial.cpp 7 Jan 2006 00:14:37 -0000 1.4
+++ source/gameengine/Ketsji/KX_BlenderMaterial.cpp 9 Jan 2006 10:03:57 -0000
@@ -139,7 +139,7 @@ void KX_BlenderMaterial::OnConstruction(
int i;
for(i=0; i<mMaterial->num_enabled; i++) {
- glActiveTextureARB(GL_TEXTURE0_ARB+i);
+ bgl::glActiveTextureARB(GL_TEXTURE0_ARB+i);
#ifdef GL_ARB_texture_cube_map
if( mMaterial->mapping[i].mapping & USEENV ) {
if(!RAS_EXT_support._ARB_texture_cube_map) {
@@ -187,7 +187,7 @@ void KX_BlenderMaterial::OnExit()
#endif //GL_ARB_shader_objects
for(int i=0; i<mMaterial->num_enabled; i++) {
mTextures[i].DeleteTex();
@@ -213,7 +213,7 @@ void KX_BlenderMaterial::OnExit()
gTextureDict = 0;
- glActiveTextureARB(GL_TEXTURE0_ARB);
+ bgl::glActiveTextureARB(GL_TEXTURE0_ARB);
if(RAS_EXT_support._ARB_texture_cube_map)
@@ -238,7 +238,7 @@ void KX_BlenderMaterial::DisableTexData(
#ifdef GL_ARB_multitexture
int i=(MAXTEX>=bgl::max_texture_units?bgl::max_texture_units:MAXTEX)-1;
for(; i>=0; i--) {
glMatrixMode(GL_TEXTURE);
glLoadIdentity();
glMatrixMode(GL_MODELVIEW);
@@ -282,7 +282,7 @@ void KX_BlenderMaterial::setShaderData(
const uSampler *samp = mShader->getSampler(i);
if( samp->loc == -1 || samp->glTexture == 0 ) continue;
if( mMaterial->mapping[i].mapping &USEENV ) {
@@ -336,7 +336,7 @@ void KX_BlenderMaterial::setTexData( boo
// no material connected to the object
if( mTextures[0] ) {
if( !mTextures[0].Ok() ) return;
glBindTexture( GL_TEXTURE_2D, mTextures[0] );
glEnable(GL_TEXTURE_2D);
setTextureEnvironment( -1 ); // modulate
@@ -352,7 +352,7 @@ void KX_BlenderMaterial::setTexData( boo
for(i=0; (i<mMaterial->num_enabled); i++) {
if( !mTextures[i].Ok() ) continue;
// use environment maps
