Litterally it means "writepicture" which isn't a correct dutch word either... I'd say it was a function name for "writing a picture file"simonharvey wrote:Please excuse my ignorance but what does:mean?ton wrote:schrijfplaatje
Windows BF - Feb 15 / Array Mod+Merge Tools
Array modifier rocks! There's also a page on mediawiki for it, here:
http://mediawiki.blender.org/index.php/ ... ayModifier
I've wanted this in Blender since day one.
hmmm,
can anyone tell me how vector MBlur works?
Thanks
Oliver
Thanks
Oliver
It works!!
Here is screenshot how it works
http://img139.imageshack.us/img139/2181/vblur8va.jpg
Great work
Great work
Yeah arrays are so usefull, this model is made of just 4 real faces:
http://www.3developer.com/temp/array.jpg
Edit: made a motion blurr test but it's does't work quite rigth (whole object gets blurred no matter what direction is it traveling), it's still very wip:
Code: Select all
(Ton Roosendaal) 2006/01/31 22:49:05 CET
Log:
Three features;
- Live scanline updates while rendering
Using a timer system, each second now the tiles that are being processed
are checked if they could use display.
To make this work pretty, I had to use the threaded 'tile processor' for
a single thread too, but that's now proven to be stable.
Also note that these updates draw per layer, including ztransp progress
separately from solid render.
- Recode of ztransp OSA
Until now (since blender 1.0) the ztransp part was fully rendered and
added on top of the solid part with alpha-over. This adding was done before
the solid part applied sub-pixel sample filtering, causing the ztransp
layer to be always too blurry.
Now the ztransp layer uses same sub=pixel filter, resulting in the same
AA level (and filter results) as the solid part. Quite noticable with hair
renders.
- Vector buffer support & preliminary vector-blur Node
Using the "Render Layer" panel "Vector" pass button, the motion vectors
per pixel are calculated and stored. Accessible via the Compositor.
The vector-blur node is horrible btw! It just uses the length of the
vector to apply a filter like with current (z)blur. I'm committing it anyway,
I'll experiment with it further, and who knows some surprise code shows up!
Ok, some notes about Mblur...(having enabled the "vec" pass)
It is nice that it takes camera motion into account as expected. It seems to me that the blur as it stands is rather excessive and completely uniform - excessive in the sense you shouldn't actually notice it is there unless you freeze-frame and uniform in the sense it doesn't just blur in the direction of motion as it should.
Secondly, if you have an object moving behind a static object, the blur goes through the static foreground object - this is to be expected as a post process and could be fixed by layering the final image. However, "AlphaOver" doesn't make much sense to me - I expected it to allow me to layer objects based on alpha. It seems to do something different.
EDIT: Just saw the above post (made while typing this) - I hope ton improves the vectorblur node to be more realistic so we can all start making nice animations
Koba
Koba
Of course there are ways to make an exelent motion blurr, other apps make it really well, ton saids he's on it.
the rendering passes are not working in this build but in cvs:
http://www.blender.org/bf/rt.jpg
I'll do a new build soon when this gets a litle more mature, after all I use them for real work, I don't want to have troubles with very wip stuff
...ahh OK this is on what i've searched for!
Oliver
Oliver
Quick Vector Mblur tute for us noobs that wanna play with it:
Add a UV Sphere. Hit "I" and select Loc. Advance to anim frame 2, move the UVsphere a bit and hit I and Loc again. Have your camera pointed to the second position.
Go to the Render buttions, go to the Render Layers tab and hit the vec button. Now render your scene with F12, making sure you're rendering the last frame, in our case frame two.
Now split your top view. On the left, change the view to Node Editor, on the right change it to UV/Image.
Hit the Composite Nodes pic button in the Node Editor, then hit Use Nodes. Disconnect the cable going from the render to the viewer by dragging it away.
Use SHift A and add a composite, then Vector blur window. Drag a line from the yellow Image circle of the Render Result window to the Vector blur, then drag two Image cables from the Vector Blur, one to the viewer and one to the composite. Then drag a blue line from Speed to Vec.
Look at Rakhi's post above for a pic of what it should look like.
On the right in UV/Image window, click the Up/down arrow button and go to Compositor. It's probably black, to update it, just drag off the Speed/Vec cable and put it back on again.
Now it should look blurry in the Composite window and life should be good.
YES!!!!
Thanks VERY MUCH for the TUT!!! this is on what i've looking for! The shiftA combi was my missing link!
Thanks Oliver
Thanks Oliver
