How do I add a face after extruding a circle with 5 sides? I tried adding face(F Key) but it did something like Fgon or something.
Could someone please tell me.
Making a face, after extruding a circle mesh(w/ 5 sides)
Solved
Shift+F works, but.... what does it do, exactly(besides covering the hole)? I would really like to know.
By the way.... extruding, then Alt+M the center isn't good. Instead of covering the hole, it combines the vertices to 1. Am I doing it correctly?
Re: Solved
Fill with faces, nothing more.e_barroga wrote:Shift+F works, but.... what does it do, exactly(besides covering the hole)? I would really like to know.
When you have the cylinder created, extrude all the vertex at the extreme you want to cap, extrude (E), confirm without move (Return), Alt+M (at center). That's all.e_barroga wrote:By the way.... extruding, then Alt+M the center isn't good. Instead of covering the hole, it combines the vertices to 1. Am I doing it correctly?
BTW, thi's a developper forum, you cand find the user forum at: http://blenderartists.org
